rhankc wrote:
Does Strokeit interfere with other softwares that have an internal mouse gesture command structure? I have been hesitant to experiment w/ strokeit for caution it may not behave with others.
Thanks for the great demo..
as far as I know it does not interfere, but I have not your same software and hardware
I use the "magic formation" start menu, which also is invoked by a gesture and my firefox has some addons that enable gestures for the web navigation.
Since Strokeit gestures are activated by a right mouse button click and drag, it may occasionally interfere with some context menu actions, or some programs: in total commander I can select multiple files inside a directory with a rclick + drag
and this activates stroke it too, but you can configure stroke it so that if total commander is running, it will not interfere.
Generally, if you experience some trouble, you can rclick over the tray icon and simply disable it - the icon changes color from white to red - and later restore it with the some action.
I believe you have just to try - it is easy to uninstall, if you don't like it.
