It is currently Mon Feb 08, 2010 11:59 pm
Registration
Login Help
Advertise Here
Rendering Workshop - Studio - still life
FAQRegisterLogin
Postby Al Hart on Sat Nov 07, 2009 4:20 pm
By popular demand I have replaced the Exterior Houses Workshop for this week with a still life.
(You can still upload your Exterior renderings to the other Workshop if you have made one)
For this weeks workshop we want to treat the model like a product we want to present and highlight in a product marketing or advertising environment.
You may change colors and materials, add lights and reflective properties, but should not add things to the place setting itself. (Imagine the developers had created the product and that it was your job to create an image for marketing)
(Also, if you fix obvious problems in the model, you may want to upload a new one for us to use)
This may involve special lighting and background effects. Give us some tips on what you did and how you did it.
You may add a table, base, etc., or other objects to help promote the product. But remember we are trying to learn about how to present objects in general - not just this specific place setting.
I have taken a 3D Warehouse model by carmil_vampire and added an apple. See what you can do with it.
[Edit: Pete has uploaded a better model. Use this one: Better model]
Guidelines
These Workshops are not a contest. People new to rendering can use them to experiment and get feedback and advice from other SCF readers. People with more experience can show us what they can do and demonstrate interesting techniques.
This Workshop is about rendering, not modeling. You can modify the model, add other geometry, add other 3D warehouse items, etc. But keep in mind that we want to see what you can do to make these existing models more presentable.
This is about all aspects of rendering - SketchUp, external add-ons, post processing, PhotoRealistic, and Non-Photorealistic. Feel free to try anything.
Upload you images, your questions, your ideas. Lets see what we can do.
You do not have the required permissions to view the files attached to this post.
Al Hart
Image IRender nXt from Render Plus
Al Hart
Operating system: XP / Vista
SketchUp version: SU 7 Pro
Re: Rendering Workshop - Still Life
Postby solo on Sat Nov 07, 2009 6:28 pm
Al
I do not wanna mess too much with your scene but I had to make a few changes, firstly the model will never look realistic as it is a weak and low poly model.
I have changed the plate for one I had, the apple for one from Michalis, the glass from one Crazy eyes made for the WH. the cutlery looks fine as well as place-mat as many folk will probably use their own textures and bump maps.
The model is slightly heavier, but for the difference in realism the gain overweighs the poly's, and even the weakest of machines will still be able to zoom through it.
I have zipped the model which was saved as a SU 6 version (that way most folks can use it)
My Portfolio:
http://solosplace.com/default.aspx
The average user never reads user guides and tutorials, that's why they are only average.
solo
Global Moderator
Operating system: ZX Spectrum
SketchUp version: SU 6 pro
Postby solo on Sat Nov 07, 2009 6:43 pm
Additionally for those that want to use a studio, here is a basic studio setup if needed, I actually use this very simple setup for many of my commercial productions, sometimes simple is best.
Play around with this setting up your camera angles, then adding lighting as needed.
Remembering that too many lights will give overlapping shadows which can ruin a studio setup.
My Portfolio:
solo
Global Moderator
Postby kwistenbiebel on Sat Nov 07, 2009 6:50 pm
solo wrote:Remembering that too many lights will give overlapping shadows which can ruin a studio setup.
Some photographers use a 3 point light setup to achieve overlapping -but soft- shadows.
Supplementary they use big reflectors to soften the shadows even more.
It depends on what the subject and the goal of the studio setup is I guess
kwistenbiebel
Postby solo on Sat Nov 07, 2009 6:55 pm
You are right Chris, they also use filters on the lights so not to create sharp shadows, there are many render apps available that can mimic this by setting the shadow opacity as well as intesity, but for those render apps without this feature one must be careful.
My Portfolio:
solo
Global Moderator
Postby pav_3j on Sat Nov 07, 2009 8:38 pm
i was about to ask if anyone had any advice on a studio setup.
you guys here are mind readers!
cheers!
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
Operating system: XP/Vista/OSX
IMAGE BASED LIGHTING
Postby solo on Sat Nov 07, 2009 11:30 pm
Okay, I found a few minutes between project phases to do a quick 1st test.
I have used Vue for this as I'm sure there will be many Twilight versions and if I don't use Vue nobody else will.
Remembering this is studio rendering so the point is NOT to have a distracting background as only the subject needs presentation. I have chosen a flat white studio with no reflection values.
I have for this test decided to use no lighting, I opted for Image based lighting instead using a HDR image. This will give the softest shadows normally (without manipulation of light values in certain renders) It will also give you image based light sources which can be very difficult to control in some render apps.
There are many reasons for using an HDR image, besides the softer shadows it also presents an image for all reflective surfaces to reflect without having an image or geometry present to obscure the scene.
Here is an image of the HDRI I used, notice it has a mustardy color to it, that color will be projected in the render, so choose your HDR according to the results you require.
I did not get to creative or detailed with my texture setup for this, just some basic presets.
There is NO post editing.
My Portfolio:
solo
Global Moderator
Postby pav_3j on Sun Nov 08, 2009 12:11 am
going to be thick here, but i don't understand the first image solo, it's a HDR, i get that much, but i don't get how it relates to the rendered image, it looks kinds abstracted.
please forgive my ignorance!
pav
pav_3j
Postby solo on Sun Nov 08, 2009 12:17 am
3 POINT LIGHTING
As Chris mentioned above, this is probably the most common studio render setup, a pretty simple way to get an acceptable result.
I have chosen omni lights (point lights) instead of spots, I did not use IES values as that I'm sure will be covered in a future workshop (too much effort to explain now)
I used a spherical image for reflections (an HDRI can be used too)
As you can see from diagram I made sure only one light had shadows selected and other two not, the reason for that is when there is three light sources there will be three shadow sources and they can ruin a studio render IMO, however some folk like that look, so it's different strokes for different folks in this regard.
The reason three lights are used and not one is if only one light was used the shadows would be darker and shaded areas will display less detail, remember this is a studio setup and NOT a real world scene, the idea is to give as much detail presentation to a product.
The image below does not show the angles very well but omni#3 is set higher (further from still life)
no post editing.
My Portfolio:
solo
Global Moderator
Postby solo on Sun Nov 08, 2009 12:29 am
Luci, most render engines have an option to use a High Dynamic range image (HDRI) in place of any physical lighting as the HDRI format has all the lighting values in the image (another technical explanation that will wear fingers down). many folk use HDRi as background images as well as a lighting source, they occasionally supplement the lighting as well.
But as you will notice I am using a studio mesh, so you cannot see the background image as the studio blocks it, thus all you will get is the reflection and lighting from it. Some apps like Vue, Vray and I believe Twilight (if I missed anyone please mention it) can use just the lighting or just the image from a HDRI giving you more control over the scene.
My Portfolio:
solo
Global Moderator
Postby Pilou on Sun Nov 08, 2009 1:14 am
What is the first: Adam or Eve? ;)
Cool render :enlight:
Speedy Galerie
Pilou
Postby dermotcoll on Sun Nov 08, 2009 1:50 am
Hi Guys
Forgive my ignorance but I am completely lost here - I am starting from level -10 and I do not see the relationship between a black and white image (HDR ) with different levels of luminance coming off the squashed cubes and the picture of the plate. You then talk about omni lights - what is the connection? I am lost - its me guys not you. Can you point me in the direction of an article / book on this subject as I dont want to waste your time asking really infantile questions from masters like you (SOLO, etc) I will then come back and break your hearts with more educated infantile questions!!!
When you burn your arse - you gotta sit on the blisters!!
dermotcoll
SketchUp version: 7.1 Pro
Postby d12dozr on Sun Nov 08, 2009 8:38 am
In the "learning to render better" theme, I can't help but repeat the sage advice I've heard on these forums many times - "A good render starts with a good model." The first thing that drew my eye in Al's render was the low-poly plate. Although the render wasn't bad, the polygonal plate ruined the whole image IMO. Just an observation from a far-from-perfect render noob :oops:
@dermotcoll, I too wish for a "HDR for Dummies" manual! However, from what I understand, Pete's HDR is a stitched-together panorama of a room. In the render program, it is "placed" around the model like the actual room from which the original picture was taken. Some weak lighting is achieved from the image, but mostly it is used for reflections, which you can see clearly in Pete's spoon. It is (at least for me) the easiest way to light the model, and usually(always?) results in soft lighting and shadows. This is why Pete added omni lights in his second render, that way he got stronger shadows, brighter colors, and caustics from the glass.
Pete, please correct me if I'm wrong!
Here is my first try. Studio setup and HDR background - sunlight off. Just some simple tone mapping when the render was complete.
d12dozr
Operating system: Vista
Postby massimo on Sun Nov 08, 2009 8:44 am
This is my try. No HDRI, but three IES emitters with a studio setup.
Raw output...
and after a quick tonemapping.
Thanks Al, Solo and Michalis for the models. :D
massimo
Operating system: win XP
SketchUp version: 6 free+7 pro
Postby Al Hart on Sun Nov 08, 2009 3:58 pm
d12dozr wrote:In the "learning to render better" theme, I can't help but repeat the sage advice I've heard on these forums many times - "A good render starts with a good model." The first thing that drew my eye in Al's render was the low-poly plate. Although the render wasn't bad, the polygonal plate ruined the whole image IMO. Just an observation from a far-from-perfect render noob :oops:
I agree. I just started rendering this model this A.M. and both the plate and the glass (with single face thin - rather than thick glass) are troublesome. Can someone upload a new model for us with a better plate and glass?
[Edit: Ignore this post. Pete had already uploaded a Better model], but I didn't see the attachment.]
Al Hart
Al Hart
by Ad Machine on 5 minutes ago
1001bit Tools - Architectural tools for Google SketchUp
Next
Advertise Here
