Swivel Viewer in Picasa
Just a couple notes about the swivel viewer (which started life as the Web Exporter, I believe) and is now used on the 3DWarehouse. It's been open-sourced and the source code is available here.
Also, it has been integrated into Picasa Web Albums, so if you are viewing a Web Album full-screen, you can click and drag left-right to flip through the images.
This is actually good timing and works very well with sahi's Create images plugin: http://forums.sketchucation.com/viewtopic.php?t=30131
Here is an album I created using sahi's plugin. View the album as a Slideshow, and click and drag left/right for the effect. The effect works on embeded albums also.
So Picasa can be a really quick way to put a 3d view of a model online.
Hi Jim,
Where is that album?
Fixed the link.
Good to know, thanks Jim
Good find Jim
