It is currently Thu Sep 02, 2010 9:54 pm
Registration
Login Help
Advertise Here
structural curvy roof answer [TUTORIAL]
FAQMembersRegisterLogin
Postby simon le bon on Tue Dec 08, 2009 11:33 pm
How to make a structural curvy roof by chang
As I think this purpose can be for a general interest, I open a special thread into this Tutorial Section to explain my way to achieve this. :enlight:
Didier Bur [Plugin] Projections version 2 UPDATED 03.07.09
Matt666_Selection manager
Jim_Selection Memory
tmtm_Selection Toys (1.4.0)
Weld by Rick Wilson
Fredo_BezierSpline
Native FollowMe tool is overpassed with this kind of 3D curve job. It makes the shape rotating along the path.
Some other solutions exists.
I have tried: wikii_FollowMe and keep But in our case, the result does not suit..
We can also use Kirill _ 2 Faces + Path following this kind of method: Copy Array Along Path tool...have a look.
but this exercise is hard for it too.
The last solution to make our shape follow our curves resides in Extrude along a path from 1001bit tools.
This one also need to be tamed. For example it absolutely doesn't like to initiate on a vertical line..
(29$ seems to be a reasonable price..)(traduction française par notre frenchy Pilou ;) )
1001bit.com - Architectural Tools for Sketchup
Once this new ExtrudeAlongPath along these prolonged curves is done, we put the shapes in coincidence two by two for IntersectWithModel and cleaning unwanted. Then the three curves and center references are put together to produce a clean basic roof element component.
clf_Shape Bender
The dome previously drawn with FollowMe tool is painted in glass material and put in place easily with the centered construction point..
My first serie with Kerkythea :ecstatic:
:o simon :lol:
simon le bon
Operating system: Win XP Home SP3
SketchUp version: 6 + 7
Re: structural curvy roof answer
Postby dale on Tue Dec 08, 2009 11:44 pm
Simon, you are truly mad... (in a great way) :thumb:
dale
Operating system: Mac osX -Windows xp
SketchUp version: 7 Pro
Postby EscapeArtist on Tue Dec 08, 2009 11:49 pm
Nicely done. Thanks for sharing.
EscapeArtist
Operating system: Win 7, XP SP3, Ubuntu, Mint
SketchUp version: 7 Free
Postby simon le bon on Wed Dec 09, 2009 12:09 am
;) Dale, You are right: I am :sketchstatic: completely mad...
Some additional KT pictures in Gallery
:freehand: simon
simon le bon
Postby dale on Wed Dec 09, 2009 12:15 am
I thought you might enjoy this Simon..[
Thin shell structural cast concrete.
You do not have the required permissions to view the files attached to this post.
dale
Postby Pilou on Wed Dec 09, 2009 12:18 am
Cool result :enlight:
I see that some plugs are used :)
Thx for the remark ;)
(d'ailleurs à la prochaine version il faudrait que je raccourcisse les bulles d'aide qui dépassent :roll:
Speedy Galerie
Pilou
Postby troyhome on Wed Dec 09, 2009 2:51 am
a very useful tut! thanks muchly
troyhome
Operating system: osx 10.6.1 snow leopard
SketchUp version: SU 7 Pro
Re: structural curvy roof answer [TUTORIAL]
Postby Mike Lucey on Wed Dec 09, 2009 2:39 pm
Thanks Simon, yes definately a madman in the nicest sense. I have added [TUTORIAL] to the topic heading for better search results. Must get Csaba to post it in the Daily CatchUp.
Mike
"Reality is merely an illusion, albeit a very persistent one." - Albert Einstein
Mike Lucey
Mayor
Operating system: Mac OSX
SketchUp version: SU Pro V7.1
Postby EarthMover on Wed Dec 09, 2009 3:15 pm
Nice tutorial Simon! I love the way you think!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D stuff http://www.facebook.com/#!/album.php?aid=178785&id=230582785069
EarthMover
Operating system: Windows Vista 64-bit
SketchUp version: Sketchup 7 Pro
Postby Ruturaj on Wed Dec 09, 2009 3:38 pm
:berserk: :sketchstatic:
Great Job. :thumb:
This tutorial is very helpful for my sketchup modeling
GooD thanKs .................. :enlight:
Thanks,
RuturaJ
Ruturaj
Operating system: window XP & Linux
SketchUp version: Sketchup 6.4 & 7.01
Postby simon le bon on Wed Dec 09, 2009 5:11 pm
Hi guys I'm confused by such friendly feedbacks.. :oops:
I would like make some addons to this thread..
I) an alternate Spider Web design
II) the possibility to use the same technique for an ovale shape:
Whaat_SubdivideAndSmooth
(re: Central box squarred for a circular result after S&S action)
(we have to say that the number of elements increases so quickly that the poor monocore SketchUp engine goes to the touch dawn in a snap :( )
III)Here is a chinese Sketchup model of the National Stadium of Pekin National Stadium_v0.skp which is dealing with that sort of questions and is very interesting to dismount...
(taken from:
archINFORM)
I have worked on it for a friend who was asking me quotations, cause he was to install a "Spider Cam" on it for a manifestation...
some pictures in PicasaWebAlbum
+++ simon
simon le bon
Postby charly2008 on Wed Dec 09, 2009 7:31 pm
Hi Simon,
this is a really good tutorial. I see that I still have to learn a lot.
Karlheinz
charly2008
Operating system: Win 7 Prof 64-bit
Postby Pilou on Thu Dec 10, 2009 2:36 am
It's curious: at any moment you have used Line2Tubes by Didier Bur? ;)
Tubes here
If you take precision = 4 you have square section so rectangular boxes in length ! ;)
Speedy Galerie
Pilou
Postby simon le bon on Thu Dec 10, 2009 6:35 pm
Pilou wrote:It's curious: at any moment you have used Line2Tubes by Didier Bur? ;)
Hi Pilou,
Good to see else tries than mine :thumb: (We often find you kindly at the "rendez-vous" :) )
You are right and not.
Line2Tubes from Didier or PipeAlongPath from TIG can be used in any case for a low poly previsu and in some cases when we want centered variations of polygones (triangle; squares; polygones; circles) . You are right I have forgotten to use them.
But I think the more often we are going to want a special shape with a special center in order to answer to two aspects: mechanical (the roof must sustain the overall weight) and esthetical too.
:idea: simon
simon le bon
Postby Carrozza on Mon Dec 14, 2009 4:48 pm
Thanks for the GREAT tutorial!
Carrozza
by Ad Machine on 5 minutes ago
Driving Dimensions - History-free parametric design in Google SketchUp
Next
Advertise Here
