πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Tutorial] Revit To SketchUp - How To
22 Posts 14 Posters 115.9k Views 14 Watching
  • F Offline
    Fletch
    Step 1 - Export From Revit
    In Revit be sure you are in a 3D view:
    Export>CAD Formats
    ----->Options
    ---------->Solids (3D views only)
    ---------->Export as polymesh>OK
    Save As Type> AutoCAD 2004 DWG Files>don't change anything else... should be "Automatic, Long" and "Current View"
    ----->Give File a Name>SAVE
    Step 2 - Import Into SketchUp
    In new SU file:
    Import>.dwg file type
    --------->find your exported dwg from Revit step above
    Options
    ----->Merge Coplanar Faces=Check
    ----->Orient Faces Consistently=NO
    ----->Units=Feet
    ----->Preserve Drawing Origin=Check
    Step 3 - Make SketchUp Do The Work
    On Didier Bur's website:
    Download and Use his amazing ruby:
    layers_materials.rb (updated link as of Jan 2017, but ruby has not been updated since 2010.
    Here's the tutorial PDF for using it. Here's the new link to the tutorial pdf
    This tool in SketchUp lets you paint things in the SketchUp file automatically by the layer they are on. Since your Revit model should be drawn on layers, this should come in very handy to automatically paint all your glass or window frames or walls almost instantly.
    Using that tool, the first option creates 'dummy' materials named for each layer in your model.
    Modify each material it creates or delete a material and create your own with the identical name to the one you deleted.
    Then, using that Layers and Materials tool, option 3 will automatically paint any material onto the surfaces on the layer for which it is named.
    Keep in mind, that this is not a science, but an art, as Revit models are frustratingly inaccurate beasts... (and CurtainWalls will all come in on the same layer and apparently you cannot change this in Revit.)
    Anyone with other opinions/easier way, please let me know!
    Fletch
    Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
      lapx
      Fletch,
      What about the reverse Sketchup to Revit? Is there a plugin for this? I recall sometime ago there being a plugin for desktop. Have there been any advances?
      Thanks,
      Lapx
      • F Offline
        Fletch
        Revit opens SKP files.
        Fletch
          asdfghjklRYAN
          Another useful tip from none other than you, Fletch. I'll check out the Ruby too. Thanks... I forgot how to do this.
          I went to the dark side for a while, but working a bit more with KT these days. I'll be sure to post some stuff for you check out when I render something worth posting. Cheers mate!~
          Your Badland Bud. 😎
          • K Offline
            kellykate2
            The links to the Ruby material changer doesn't seem to point to the right page on the Ruby Site. I'm having trouble finding the plugin? Is this link still up to date???
              Didier Bur
              Here is the correct link: http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/em_ren_page.htm
              The site's currently almost OOO, complete update is planned for 06.12.10 πŸŽ‰
              DB
                duske
                @didier bur said:
                hey, unfortunately these links dont work ;///
                could someone explain the STEP 3 and give these links? because i dont know which plugins to choose
                • G Offline
                  Hi Duske,
                  Didier has completely reorganised that site since his above post. Here is the plugin:
                  http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=219
                    duske
                    thanks πŸ˜‰
                    • F Offline
                      Fletch
                      http://www.crai.archi.fr/rubylibrarydepot/ruby/Layers_materials.pdf
                      Didier - any idea where we can find this Layers_materials.pdf that teaches how to use the plugin?
                      I have searched all my archives and had no luck in finding it, sorry. 😞
                      Fletch
                        Didier Bur
                        I finaly remembered that I had to find it.
                        Here it is (not really a user guide, just a simple description of what the script does).
                        It is now also included in the zip archive on my site.
                        Sorry for the delay,
                        DB
                        • MatteM Offline
                          Matte
                          From a time/design stand point. I am "thinking" it is best to do initial design phase and each client design change completely in SU. And when design presentations are done and the go ahead to do Construction Documents is given, only then redraw everything according to the approved SU model in Revit from scratch?
                          Not sure if the import/export from one to the other actually saves lots of time in the long run? I have only been using Revit for one day (so I do not know really of what I am talking About πŸ˜‰! (Seams simular to Architectural Desktop, but more rough?) I started trying to do everything in Revit from scratch as my friend directed. Just walls and windows so far..... It looks like it will be real time consumingto do the property lines trees textures and existing/demo/and 2 or 3 new 3D drawing versions to show client? Should this be a breeze in Revit once I get the hang of things? Or does my initial thoughts have any value? What is the steps SU and Revit users use to get things done? I can see the value in doing Construction Docs in Revit, but very confused on the best way to proceed?
                            You can import a SKP directly into Revit - it should be imported as a 'massing element'; then you convert the various parts of it into walls, roof, floors, curtain-walling etc using Revit's tools so they can have the required 'intelligence' they need for later use... after that you can start looking at adding the secondary elements like doors etc and progress to your CDocs. If you don't import it as a massing element a SKP comes in as a 'block' that is relatively useless later - except for some fixed thing like a reception counter that doesn't need intelligence later...
                            SKP into Revit is therefore relatively straightforward BUT needs some work to meld the two together. In fact secondary building around your main building in Revit are more easily made as SKPs and imported.
                            If you export from Revit [as DWG/DXF] and thence into a SKP, you get a 'layered mess', with duplicated components that are actually identical - e.g. curtain-wall mullions. This makes the reverse process 'Revit into SKP' much more cumbersome, so much so it is not recommended except for very simple projects...
                            • MatteM Offline
                              Matte
                              Thanks TIG,
                              I have been watching many youtube videos and came to two conclusions so far..which one do you feel makes more sence? They both will work, just not sure which is more "practical".
                              1 - Draw each option in Revit, for rendering and presentation graphics only, export to SU for image creation. (Revit and Con. Docs will be required in either option).
                              2 - Do all design and change options in SU. When final design is approved either draw from scratch or import to Revit and do all the appropriate changes to make it construction Doc ready?
                              The videos show me that Revit is more capable then I originally thought it was?
                              Thanks for your advice,
                              Matte
                                I'd have thought option 2 is the most applicable in your case...
                                • MatteM Offline
                                  Matte
                                  Thanks TIG,
                                  I think I'll follow that route. It's hard to shift away from SU as I allready known set most of the tools, but Revit seams like it will not be too bad and I can still import things from SU that I can not create in Revit. Thanks again!
                                  • F Offline
                                    Fletch
                                    Be careful importing SU to Revit - it looks like it's in Revit - but it can not be rendered, and is fairly useless (at least it was until 2 years ago. I haven't used Revit in 2 years. I can build a curvy sink in 3D in SketchUp in a few minutes from a couple photos... takes hours in Revit. 😐
                                    If I try to bring the sink into a "family" in Revit it may show up on screen, but they deliberately do not allow you to render it.
                                    Why? Well, I could be wrong, but as near as I can tell, they simply don't want Revit users to be able to use all the great free 3D models out there, but rather to have to pay for new unique content specifically made for Revit. πŸ˜’
                                    They will argue that you can't "flex" a 3D model from the warehouse, etc. But I will argue - since when do I need to "flex" a sink? A sink is a sink, and millions of models are like that - no reason I should have to create them especially in Revit for this.
                                    Also, you can not smooth geometry (as of 2 years ago) in Revit (at least I never discovered a way). Segmented curves in your renders. Joy.
                                    Fletch
                                      sauerkrauten
                                      I just imported this sink/cabinet as wallbased normal cabinet, gave it new materials and render, so itΒ΄s ok if you model curves if needed, the tap is lacking curvature, but so is the modeling.
                                      Revit render
                                      Octane render from sketchup
                                      • brodieB Offline
                                        brodie
                                        I seem to keep coming back to this tutorial. Thanks for the tips here.
                                        -Brodie
                                          matt.gordon320
                                          Just in case you guys hadn't come across this...here's the workflow that FormFonts uses to convert all of their Revit models into SketchUp.
                                          (formfonts3dmodels.com)
                                          • 1 / 2
