It is currently Tue Feb 09, 2010 12:00 am
Registration
Login Help
Advertise Here
Notepad++ users: heads up
Moderators: Jim, ScottLininger
FAQRegisterLogin
Postby Didier Bur on Mon Jan 19, 2009 11:16 pm
Using Notepad to code Ruby scripts, I was tired to write the names of SU-Ruby methods that have long names (yes, I'm a lazy guy). So I have added all the Sketchup Ruby methods to the standard Ruby auto-completion file that comes with Notepad++.
To use it: set auto-completion on in the preferences, set of course Ruby as your coding language, and move the attached XML file in the directory: YOUR_NPP_DIR\plugins\APIs (where YOUR_NPP_DIR is the directory in which you installed Notepad++).
First make a backup of the original ruby.xml file, just in case !
You do not have the required permissions to view the files attached to this post.
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://www.crai.archi.fr/RubyLibraryDepot
User avatar
Didier Bur
Operating system: XP
SketchUp version: 6-7
Re: Notepad++ users: heads up
Postby thomthom on Tue Jan 20, 2009 8:16 am
Awesomeness! :berserk:
Thomas Thomassen — SketchUp Monkey
My Plugins
User avatar
Global Moderator
Name: Thomas Thomassen
Operating system: Windows7/Vista/XP/OSX10.4
SketchUp version: 6.4&7.1 Pro
Postby Matt666 on Tue Jan 20, 2009 10:38 am
Excellent !
Frenglish at its best ! :)
My scripts
User avatar
Matt666
Operating system: XP Sp2
SketchUp version: 7 Free
Postby Jim on Tue Jan 20, 2009 11:52 am
Thanks Didier. I don't use Notepad++ myself, but auto-complete can be a time-saver. I always wanted to create one for my editor.
However if you were truly lazy, you would have searched here for "notepad autocomplete"...
viewtopic.php?f=180&t=4796&p=25556&hilit=notepad+autocomplete#p111076
I hate to see effort spent on something that has already been done. Any suggestion on how to organize and make things easier to find? I have added these to the Ruby Resources sticky post in the Ruby Forum.
User avatar
Jim
Global Moderator
Operating system: XP Pro SP3
SketchUp version: Google Pro 7.1
Postby TIG on Tue Jan 20, 2009 3:12 pm
Thanks...
User avatar
Operating system: Vista
SketchUp version: Latest 7 Pro
Postby Heven7_floor on Tue Jan 20, 2009 5:57 pm
I am learning to code by RDE and bride.rb , and find Notepad++ ability as your all suggestions :thumb:
but I am trying be practice in RDE editor, I hesitate that I should change behavior to learning with NotePad++ or RDE :puke:
Do Notepad++ can bridge script to run in SU instantly as RDE :roll: ?
User avatar
Heven7_floor
SketchUp version: SU 6
Postby Didier Bur on Tue Jan 20, 2009 9:30 pm
:evil: stupid me. I'll consider a "search" next time before doing the job myself :bounce:
I used to code with RDE (sometimes buggy. What I miss in Notepad++ is the code explorer of RDE, but believe me, Notepad++ is much better. I tried several code editors since 20 years, and I find Notepad++ the most powerful and cool to use, especially the braket/brace matching highlight, the syntax folding and the lines bookmarking. Worth a try !
User avatar
Didier Bur
Postby Heven7_floor on Wed Jan 21, 2009 4:12 am
As the few hours trying with Notepad++, I was interested in its feature, so it is quite valuable IDE
Thanks Didier , your suggestion is impressive :D
User avatar
Heven7_floor
Postby Tomasz on Wed Jan 21, 2009 11:40 am
Thank you, Didier!
I am using Notepad ++ since very beginning and I like it very much.
I find it very useful.
Tomasz
Tomasz
Operating system: WinXP \ Vista
SketchUp version: SU 6+ Free/Pro
Postby remus on Tue Oct 06, 2009 6:43 pm
just got round to installing this, thanks very much for your effort in putting this together :thumb:
User avatar
remus
Global Moderator
Operating system: vista
SketchUp version: 7.whatever
Postby TBD on Wed Oct 07, 2009 6:04 am
any IDE can be used with SketchUp Bridge if it allows running another process with the current file in command line.
I need to open source my play tools as I dont have time to improve them anymore - I made an autocompletion tool which uses SU Ruby, so you have all methods that are in an Object (even those custom defined later) at your fingertips.
SketchUp Ruby Consultant | Podium developer
http://plugins.ro
User avatar
TBD
Operating system: iMac 20", Mac OSX 10.5.8
SketchUp version: Pro 7.x
Postby NewOne on Wed Oct 07, 2009 7:47 am
here is how you do it using TBD's bridge sollution viewtopic.php?f=169&t=6903#p137855
User avatar
NewOne
Operating system: Windows XP
SketchUp version: 7
by Ad Machine on 5 minutes ago
Twilight Render - Design, Render, Relax
Ad Machine
Robot
Advertise Here
Who is online
