[Plugin Library] LibFredo6 - v12.9a - 13 May 22
IMPORTANT: from now on, LibFredo6 and all my plugins are ONLY maintained for SU2017 and above. If you run a legacy version of Sketchup (up to SU2016), you can find the frozen legacy versions of LibFredo6 and my plugins here.
The information on LibFredo6 is maintained on the Plugin Home Page of LibFredo6. This is also where you can download the RBZ file.
REQUIREMENTS:
- Sketchup version: SU2017 and above (for Mac M1, SU2021 and above)
- Platform: Windows and Mac OSX
- Usage: Free
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video:
LibFredo6 is a shared plugin library used by most of my plugins. LibFredo6 takes care, among others, of enriching my plugins with a few capabilities such as default parameters, language translation, Check Plugins for Update, Trace logging, etc.
It is NOT a standalone plugin. It must be installed once and updated as needed when new versions are published.
Thank you!
Installed and running fine. -
I have downloaded the plugins. I will try to look at the translation files tomorrow.
Bonjour,
Comment activer l'affichage ?
Have you tried downloading the file again?
I am getting constant error when trying to extract libFredo6 3.1A
finally got it after 5 downloads....works fine. -
fantastic work....so easy to use and effective
NEW VERSION 3.1bavailable.
It is necessary for running the upgrade to FreeScale 2.0b.see main message of this thread
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=145336#p144178Fredo
I followed the installation instructions on your pdf to the letter, and I'm rewarded with an amazing nothing. You installation instructions are unclear and inadequate
You wont get anything visible after you install libfred06. Have you installed freescale?
I take back my above post. I've got it to work now, I'm just a bit tired. On that note, well done sir
Glad to hear its working
NEW VERSION 3.1c
Needed for for FreeScale 2.0c
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 -
NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
Thank you for sharing such awesome tools! You are truly a ruby script-master!
Hello.
This is Korean language files of LibFredo6 & FreeScale.
I really love this awsome plugin.
Thanks, Fredo6!
Hello.
Thanks, Fredo6!
The 2 files seems to work, though I can't really help to check with my laptop. At least it shows up in the translation dialog box.
Does 크기 변형 means "Scaling"If other users want to try, just extract the file and
- drop LibFredo6_KO.lang into the LIBFREDO6_Dir_31 folder
- drop FreeScale_KO.lang into FREESCALE_Dir_20 folder
Thanks very much
Fred
a very useful tool, thank you very much.!
NEW VERSION 3.1d
Needed for for FreeScale 2.0d (the previous version 2.0c had a major bug).
NEW VERSION 3.1e
Needed for for FreeScale 2.0e
