As the polylines remains parametric as long as it is a curve, you can later change the parameters, and move, add or remove vertices.
Finally, as for other extensions of Bezierspline, you can convert any Sketchup curve into a Polyline with Round corners.
Here is a small video about it.
Indeed you need to install BezierSpline 1.21 beforehands. If not already done, just refer to the post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563#p100509.
For installation of BZ__Arc, you just need to
- drop the attached file BZ__Arc.rb in your BZ_Dir_12 folder
- drop the two icon files into the subfolders IMAGES_CadFather and IMAGES_Standard which are located in BZ_Dir_12 folder
I am interested to know if it is useful in practice.
This extension is integrated in the main release of BezierSpline 1.4. See this this post for download
Fredo
