It is currently Tue Feb 09, 2010 1:46 pm
Registration
Login Help
Advertise Here
Slicer
Moderators: Jim, ScottLininger
FAQRegisterLogin
Slicer
Postby TIG on Fri Dec 21, 2007 7:31 pm
Moved from the 'Roof' thread...
matt77 wrote:Excellent Script. Many thanks -- works a treat for me!!!
I must commend you also on another of your scripts that I find invaluable at work. It's your slicer ruby. It comes in very handy for working out the floor space across very large master-plan massing models. It has saved me so much time. Thank you. I'm not sure it was ever intended for this, but if you set the floor to ceiling height say 3 metres, but don't give the slices any thickness, then run the script across a large grouped area of buildings then explode the floor slabs within the main group, by using the area tool with all faces within that group selected you get a total floor space for that whole area. You may have to delete the top slices so that you don't include the roofs. But very, very handy indeed...
Whilst using your most recent roof script I was impressed in the way that you could assign a material and a layer to the new roof.
I have a request. (Not that your not busy enough as it is)
Is it possible to implement this within in the slicer ruby? So that the when you create the new slices you have an option of also assigning a material to the new slices. In this way you could have separate materials for residential, commercial and retail space. This information regarding the areas assigned to the materials could be then exported to an excel sheet. Giving you a detailed breakdown very quickly regarding your model.
Matt
A few months ago we started using Slicer.rb for exactly the same thing - to get a rough idea of the floor-space in massing blocks on master-plans [although its original use was for making 3D card models from a Sketchup volume - cheap 3D-printer !]
Not so long ago I added a make your own layer and pick materials on the fly option to VolumeCalculator.rb. Since this a son (or perhaps grandson ?) of Slicer it'll be pretty easy to implement (I hope)... I'll add it to the list of things to do.
Watch this space...
User avatar
Operating system: Vista
SketchUp version: Latest 7 Pro
Re: Slicer
Postby matt77 on Fri Dec 21, 2007 7:31 pm
Thank you very much.
I'll keep an eye out for any developments.
Many thanks
Matt
matt77
Re: Slicer
Postby TIG on Fri Dec 21, 2007 7:33 pm
Here is v3.0 of Slicer.rb.
You can now choose / make its Layer on the fly and select any 'Colour'...
Enjoy...
sas/Ruby/Slicer.rb
User avatar
Re: Slicer
Postby Juju on Fri Dec 21, 2007 7:34 pm
I get this error message with Slicer.rb (version 3.0), see image attached.
Keeping things organised is not a sin. ;)
User avatar
Juju
Operating system: XP SP3 / OS X / Vista SP1 / Win 7 RC1
SketchUp version: SU 7.0.10274 (Pro)
Re: Slicer
Postby TIG on Fri Dec 21, 2007 7:35 pm
Juju wrote:I get this error message with Slicer.rb (version 3.0), see image attached.
I apologise. I uploaded a version that's customized to my menu setup by mistake ! Of the 40 or so who've viewed it so far you are the only one to point it out... Here's v3.1 that's fixed to suit all.
sas/Ruby/Slicer31.rb
User avatar
Re: Slicer
Postby seasdes on Fri Dec 21, 2007 7:35 pm
Thank you TIG for another useful script
Walter
seasdes
Re: Slicer
Postby not registered yet on Fri Dec 21, 2007 7:36 pm
Thanks so much for the new version - works great! I'm using it similarly to the original purpose TIG mentioned, as a cheap 3D printer. Now to create a (cheap) automated way to cut them out!
best,
Matt
[mattratto]
not registered yet
by Ad Machine on 5 minutes ago
Piranesi 2010 - Design to Art
Ad Machine
Robot
Advertise Here
Who is online
