EntitiesObserver and Attributes - work around
Hi!
Im trying to figure out how to use the add_observer method on the entities in a group, and saw TTs list (url below)
http://www.thomthom.net/software/sketchup/observers/#ViewObserverHere my worst nightmare came through... The Sketchup::EntitiesObserver - onElementModified(entities, entity) dont work. Just as I had experienced myself.
What I try to accomplish (see the code below), is to keep track of the area of a specific face, named yv_face_area (green color). Initially I have set an attribute to the rsgroup (which contains the yv_face_area) set_attribute("rsdict, "area", area). It seems to work fine.
But, as mentioned, the onElementModified method dont seems to work.
Anyone haves an idea how to work around this problem?
snippet:
mod = Sketchup.active_model # Open model ent = mod.entities # All entities in model sel = mod.selection # Current selection class MyEntityObserver < Sketchup::EntityObserver def onEraseEntity(entity) #this work UI.messagebox("onEraseEntity: " + entity.to_s) end end #class class MyEntitiesObserver < Sketchup::EntitiesObserver def onElementModified(entities, entity) #dont seems to work UI.messagebox("onElementModified: " + entity.to_s) end def onEraseEntities(entities) #this seems to work UI.messagebox("onEraseEntities: " + entities.to_s) end def onElementRemoved(entities, entity_id) #dont seems to work UI.messagebox("onElementRemoved: " + entity_id) end def onElementAdded(entities, entity) #this seems to work UI.messagebox("onElementAdded: " + entity.to_s) end end #class pts = [] pts[0] = [ 0, 0, 0] pts[1] = [ 1000.mm, 0, 0] pts[2] = [ 1000.mm, 1000.mm, 0] pts[3] = [ 0, 1000.mm, 0] pts[4] = [ 0, 0, 1000.mm] pts[5] = [ 1000.mm, 0, 1000.mm] pts[6] = [ 1000.mm, 1000.mm, 1000.mm] pts[7] = [ 0, 1000.mm, 1000.mm] 5.times do |i| rsgroup = ent.add_group rsgroup.entities.add_face pts[0..3] yv_face_height = rsgroup.entities.add_face pts[4..7] rsgroup.entities.add_face pts[0], pts[3], pts[7], pts[4] rsgroup.entities.add_face pts[3], pts[2], pts[6], pts[7] rsgroup.entities.add_face pts[1], pts[2], pts[6], pts[5] yv_face_area = rsgroup.entities.add_face pts[0], pts[1], pts[5], pts[4] yv_face_height.pushpull rand(1000.mm) yv_area = yv_face_area.area.to_m.to_m yv_face_area.material = (0xAADEAA) rsgroup.set_attribute "rsdict","area", yv_area yv_face_area.set_attribute "rsdict", "area2", yv_area point = Geom::Point3d.new (1100.mm * i, 0, 0) t = Geom::Transformation.new point rsgroup.transform! t rsgroup.add_observer(MyEntityObserver.new) rsgroup.entities.add_observer(MyEntitiesObserver.new) end #times_do ent.each do |o| point = Geom::Point3d.new (0, 1100.mm, 0) t = Geom::Transformation.new point o.transform! t end #each_do i = 0 ent.each do |o| attr = o.get_attribute "rsdict","area" if attr UI.messagebox "Attr - Area: " + attr.to_s + " m² - n: " + i.to_s i = i + 1 end end
http://www.thomthom.net/software/sketchup/observers/#EntitiesObserver
Here I noted thatEntitiesObserver.onElementModified
is working in SU8...btw - what are you planning to do on the event? Make model changes? I found that can often mess up other scripts or even crash SketchUp.
Also, when testing observer I don't use messageboxes as the silly manual does. If the observer trigger many events you'll be stuck with clicking messageboxes. I prefer to use
puts
- or even win Win32API to output to DebugView. -
When a wall is resized I want the walls area-attribute to update. Thats basically what Im trying to do.
Great to know that SU8 might work.
About using put, I dont know how to use it? Is it possible to use it with Alex Screyers Ruby Editor? I have tried without any output. Im interested to know more about Win32Api. Is it something I need to download?
It is is
puts
, not "put". (It is short for "put string".)puts()
outputs toSTDOUT
so you must have some console open before you call it. You can use the built-in Ruby Console that comes with SketchUp, from the Window menu. (Or you can use also Alex's WebConsole. It is your choice.)You do not need to worry about the Win32API, or win32-api libraries, at this time. (Using them is at the advanced level.)
If you are developing plugins, you should be using the latest version of SU 8, not 7. (You can still have 7 installed if you need to import/export DWG files. But that is really all you should be using 7 for.)
Next problem:
When deleting a group, and undoing - it looses all the observers.
Well, have to look at that tomorrow.Luckily it keeps the attributes as far as I can see...
Dan, ok I stay away from win32api for a while
Think I found a usable solution to this problem:
(It only works in SU8+)- Add EntitiesObserver to each Entity with the attributes("rsdict","area")
- Keep the EntitiesObservers when undoing a deleted group
- Keep the EntitiesObservers when copying a group.
- Add EntitiesOberservers to each group with the attributes ("rsdict", "area")
The solution seems to be simple: - Every time something happens (like undo or change, etc.) the executed observer iterates through each entity and, in my case, when it finds an entity with the attributes ("rsdict", "area") it simply add_observer(MyEntitiesObserver.new).
It can be testet with the two pieces of codes below.
In this example it messures the area of the green face, when you pushpull the red face at the top.In the first codepiece it draws some boxes and adds some attributes, but dont add any observers. Try to run the code a few times so it will produce a number of boxes.
mod = Sketchup.active_model # Open model ent = mod.entities # All entities in model sel = mod.selection # Current selection pts = [] pts[0] = [ 0, 0, 0] pts[1] = [ 1000.mm, 0, 0] pts[2] = [ 1000.mm, 1000.mm, 0] pts[3] = [ 0, 1000.mm, 0] pts[4] = [ 0, 0, 1000.mm] pts[5] = [ 1000.mm, 0, 1000.mm] pts[6] = [ 1000.mm, 1000.mm, 1000.mm] pts[7] = [ 0, 1000.mm, 1000.mm] 10.times do |i| rsgroup = ent.add_group rsgroup.entities.add_face pts[0..3] yv_face_height = rsgroup.entities.add_face pts[4..7] rsgroup.entities.add_face pts[0], pts[3], pts[7], pts[4] rsgroup.entities.add_face pts[3], pts[2], pts[6], pts[7] yv_face_length = rsgroup.entities.add_face pts[1], pts[2], pts[6], pts[5] yv_face_area = rsgroup.entities.add_face pts[0], pts[1], pts[5], pts[4] yv_face_height.pushpull rand(1000.mm) yv_area = yv_face_area.area.to_m.to_m yv_face_area.material = (0xAADEAA) #green yv_face_height.material =(0x8811FF) #red rsgroup.set_attribute "rsdict","area", yv_area yv_face_area.set_attribute "rsdict", "yv_face_area", yv_area yv_face_length.set_attribute "rsdict", "yv_face_length" , 0 yv_face_height.set_attribute "rsdict", "yv_face_height", 0 point = Geom::Point3d.new (1100.mm * i, 0, 0) t = Geom::Transformation.new point rsgroup.transform! t end #times_do ent.each do |o| point = Geom::Point3d.new (0, 1100.mm, 0) t = Geom::Transformation.new point o.transform! t end #each_do
Second piece of code: - Here it add the observers. Every time the code is executed it will asign the observers. And it seems like it doesnt matter how many times you do it.There will only be one observer for each entity.
mod = Sketchup.active_model # Open model ent = mod.entities # All entities in model sel = mod.selection # Current selection class MyModelObserver < Sketchup::ModelObserver def onTransactionUndo(model) #UI.messagebox("onTransactionUndo: " + model.to_s) Sketchup.active_model.entities.each do |o| attr = o.get_attribute "rsdict","area" if attr o.add_observer(MyEntityObserver.new) o.entities.add_observer(MyEntitiesObserver.new) end end end end #MyModelObserver #Adding ModelObserver - Undo Sketchup.active_model.add_observer(MyModelObserver.new) class MyEntityObserver < Sketchup::EntityObserver #def onEraseEntity(entity) #this work #UI.messagebox("onEraseEntity: " + entity.to_s) #end #def onChangeEntity(entity) #UI.messagebox("onChangeEntity: " + entity.to_s) #end end #class class MyEntitiesObserver < Sketchup::EntitiesObserver def onElementModified(entities, entity) attr_length = entity.get_attribute "rsdict", "yv_face_length" attr_height = entity.get_attribute "rsdict", "yv_face_height" if attr_length entities.each do |i| attr_area = i.get_attribute "rsdict", "yv_face_area" if attr_area yv_area_new = i.area.to_m.to_m #UI.messagebox "Length changed - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²" i.set_attribute "rsdict", "yv_face_area", yv_area_new end #attr_area end #each do end #if attr_length if attr_height entities.each do |i| attr_area = i.get_attribute "rsdict", "yv_face_area" if attr_area yv_area_new = i.area.to_m.to_m UI.messagebox "Height changed - green face - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²" i.set_attribute "rsdict", "yv_face_area", yv_area_new end #attr_area end #each do end #if attr_height end #onElementModified_end end #class i = 0 ent.each do |o| attr = o.get_attribute "rsdict","area" if attr o.add_observer(MyEntityObserver.new) o.entities.add_observer(MyEntitiesObserver.new) i += 1 end end UI.messagebox "number of boxes: " + i.to_s
There is still the problem that you modify the model on observer events. When you do that you interfer with any operation that is going on - which might be in the middle of a start/commit operation of another plugin or native tool. You'll be adding to the Undo stack - causing unexpected behaviour when the user expects to undo their last operation but instead the undo is your injected attribute change.
Model change at observer events may cause bug splats. -
Model change at observer events may cause bug splats.Im not sure how to do it yet, but I think a solution could be to remove the observers, when editing the group, and adding the observer again when finished.
It seems to be very quick to add observers to ALL the entities in the model, and its not possible to add more than one observer to each entity, so you dont have to take care if the entity allready has got one.
Strongly recommend you use observers sparsely. Also what you do within the events. Some events trigger many times a second - and that mean you can easily bog down SketchUp.
Yes you can add more than one observer.
What I meant was, if you do like this:
(adding 3 identical observers to one entity)
Code:
mygroup.entities.add_observer(myEntitiesObserver.new)
[....]it will only have one myEntitesObserver attached to mygroup. - not three. That means its easier to handle... You dont need to check if its allready added, its faster just to add new one to every entities.
Yes you can add more observers to one entity eg. MyEntitiesObserverWatchFaces and MyEntitiesObserverWatchEdges
Not correct. For each new instance of your observer class you attach you add an observer:
Here I first drew one line. Then added another observer. When I draw a second line I get two observer triggering - and they are both of the same class.However, if you attach the same instance of your observer to the same element, then it's no extra observers added:
Here I only ever get one observer triggering - because I'd only ever attached a single instance.I store the reference to the observers I use. Then I remove it - just to be sure.
` @entities_observer = myEntitiesObserver.new
def self.observers
mygroup.entities.remove_observer( @entities_observer )
mygroup.entities.add_observer( @entities_observer )
end`Just to be sure
Ok, maybe you are right, but to me it seems like it only triggers once, even though I have attached it many times in a row.
Could it be that it is overwritten each time its attached?! As far as I can see its not possible to see which observers is added in the model.
If you try the code I have attached above you can what I mean...
(Run the first code a couple of times to get some boxes without observers, then run the second code as many times you want, and the observers only triggers once) -
If you attach the same instance. But if you do like in my second example, you keep a reference to an instance and use that reference when you attach observers it won't create duplicates.
Correct, there isn't.
(Run the first code a couple of times to get some boxes without observers, then run the second code as many times you want, and the observers only triggers once)Got a sample model with "Boxes"?
What do you do to trigger the events?Btw - you know that
model.entities
isn't all the entities in the model? It's just the root context. The rest of the entities is inside Groups, Components and Image entities.
http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/ -
What do you do to trigger the events?In post number 7 in this thread there are two pieces of codes attached...
The 1. piece of code draw boxes without observers, the 2. piece of code add observers to the boxes.
When you have deleted a box, try to undo, and it attaches new observers in a way that it solves the problem with lost observers.It triggers when the red face is modified (push/pulled) using the def onElementModified(entities, entity) in the "MyEntitesObserver", and it messure the area of the green face.
Ok - seeing it now. Still trying to work out the code flow.
But you still have the issue with setting observers adds to the Undo stack.
So when you push pull - the observer triggers and add an event to the Undo stack. So when the user press undo after push/pull he first undo the attribute change - then he has to undo again to undo the push pull.
If the user undo just one - he will have undone the attribute change, but not the push-pull - making your data invalid. Also, the user is likely to become frustrated that Undo is working unpredictably. -
Worked out why your observer triggered only once:
The set_attribute call short-circuited the other events. When I commented outset_attribute
and also changed theUI::Messagebox
to this:
puts "#{self} - Height changed - green face - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²"
You will then see that all theMyEntitiesObserver.new
adds new observers - and doesn't remove the old ones. You'll see it output events for each instance you created. It was just your model change that prevented the events to propagate.<span class="syntaxdefault"><br /> mod </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model </span><span class="syntaxcomment"># Open model<br /> </span><span class="syntaxdefault">ent </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities </span><span class="syntaxcomment"># All entities in model<br /> </span><span class="syntaxdefault">sel </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection </span><span class="syntaxcomment"># Current selection<br /><br /> </span><span class="syntaxkeyword">class </span><span class="syntaxdefault">MyModelObserver </span><span class="syntaxkeyword">< </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">::</span><span class="syntaxdefault">ModelObserver<br /> def onTransactionUndo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">) <br /> </span><span class="syntaxcomment">#UI.messagebox("onTransactionUndo: " + model.to_s)<br /> </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">do |</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br /> </span><span class="syntaxdefault">attr </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute </span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br /> <br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">attr <br /> o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new) <br /> </span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new) <br /> </span><span class="syntaxdefault">end<br /> end <br /> end <br /> end </span><span class="syntaxcomment">#MyModelObserver<br /> #Adding ModelObserver - Undo<br /> </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyModelObserver</span><span class="syntaxkeyword">.new)<br /><br /> class </span><span class="syntaxdefault">MyEntityObserver </span><span class="syntaxkeyword">< </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">::</span><span class="syntaxdefault">EntityObserver <br /> </span><span class="syntaxcomment">#def onEraseEntity(entity) #this work <br /> #UI.messagebox("onEraseEntity: " + entity.to_s) <br /> #end<br /> <br /> #def onChangeEntity(entity) <br /> #UI.messagebox("onChangeEntity: " + entity.to_s)<br /> #end<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#class<br /><br /> </span><span class="syntaxkeyword">class </span><span class="syntaxdefault">MyEntitiesObserver </span><span class="syntaxkeyword">< </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">::</span><span class="syntaxdefault">EntitiesObserver <br /> def onElementModified</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">, </span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">) <br /> </span><span class="syntaxdefault">attr_length </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute </span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">, </span><span class="syntaxstring">"yv_face_length"<br /> </span><span class="syntaxdefault">attr_height </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">entity</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute </span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">, </span><span class="syntaxstring">"yv_face_height" <br /> <br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">attr_length <br /> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">do |</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /> </span><span class="syntaxdefault">attr_area </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute </span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">, </span><span class="syntaxstring">"yv_face_area"<br /> <br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">attr_area<br /> yv_area_new </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br /> </span><span class="syntaxcomment">#UI.messagebox "Length changed - area before: " + attr_area.to_s + " m² - area after: " + yv_area_new.to_s + " m²" <br /> #i.set_attribute "rsdict", "yv_face_area", yv_area_new<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#attr_area<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#each do<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#if attr_length<br /> <br /> <br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">attr_height <br /> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">do |</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /> </span><span class="syntaxdefault">attr_area </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute </span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">, </span><span class="syntaxstring">"yv_face_area"<br /> <br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">attr_area<br /> yv_area_new </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_m<br /> puts </span><span class="syntaxstring">"#{self} - Height changed - green face - area before: " </span><span class="syntaxkeyword">+ </span><span class="syntaxdefault">attr_area</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s </span><span class="syntaxkeyword">+ </span><span class="syntaxstring">" m² - area after: " </span><span class="syntaxkeyword">+ </span><span class="syntaxdefault">yv_area_new</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s </span><span class="syntaxkeyword">+ </span><span class="syntaxstring">" m²" <br /> </span><span class="syntaxcomment">#i.set_attribute "rsdict", "yv_face_area", yv_area_new<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#attr_area<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#each do<br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#if attr_height<br /> <br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#onElementModified_end <br /> </span><span class="syntaxdefault">end </span><span class="syntaxcomment">#class<br /><br /> </span><span class="syntaxdefault">i </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">0<br /> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">do |</span><span class="syntaxdefault">o</span><span class="syntaxkeyword">|<br /> </span><span class="syntaxdefault">attr </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute </span><span class="syntaxstring">"rsdict"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"area"<br /> <br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">attr <br /> o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntityObserver</span><span class="syntaxkeyword">.new) <br /> </span><span class="syntaxdefault">o</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">MyEntitiesObserver</span><span class="syntaxkeyword">.new)<br /> </span><span class="syntaxdefault">i </span><span class="syntaxkeyword">+= </span><span class="syntaxdefault">1<br /> end<br /> end<br /><br /> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox </span><span class="syntaxstring">"number of boxes: " </span><span class="syntaxkeyword">+ </span><span class="syntaxdefault">i</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br /></span>
I'm not sure how to do these tests.
Are you saying if I pushpull one red face, it triggers events for every instance?? (If there is 200 boxes it triggers 200 times?) (box=instance)
Or will it trigger the number of times, you have runned the script which adds observers? (instance = observer added)
(Because in my case it only shows the UI.messagebox once) -
(Because in my case it only shows the UI.messagebox once)As describe above - in your case it triggers only once because when you modify the model with
set_attribute
it blocks all the other observers attached. Comment out theset_attribute
code and you'll see all the observers you added will trigger.
And then it's the issue with the Undo stack which I also mentioned.
