Script idea...
Thank you for all scripts created here !!
I have a suggestion (here for french users, and for the based post) for a new script which I believe is feasible for someone familiar with ruby script.
Beeing a carpenter, I often use wood textures and the problem is that one time out of two they are not in the rigth orientation as far as the wood grain is concern.
Most of the time the wood grain has to be oriented along the longest dimension of a surface.
It would be nice to have a ruby script that detect this situation and does orient the grain of the wood texture in the right direction.Procedure :
1- Selection
2- Texturise faces in along the longest dimension
3- Question : is it the right sense ?
3b - No ? Rotate textures at 90ยฐ.
4- Validate.What do you think about that ? Reasonnable ? Do you agree it will be a nice script ?
Thank you !!
PS : Thanks to Bert for the translation of this post But he doesn't translate the end !! The faults are mine !!
now youve mentioned it the idea makes perfect sense. It would be cool to see it done, although its a pity its not a native SU feature, then it could be on all the time.
One potential issue: what happens with end grains?
Even better: Get the plugin to check primary orientation of component/group and apply lengthwise to longest sides. At the same time, apply end-grain texture to shortest ends. Of course, we still need a way to manually override this. The plugin could even have a drop-down selection for different woods.
I tihnk the manual over ride thing would be pretty simple really: youd jsut run the script, and thne if you needed to change anything youd just change it as noraml. Perhaps have a 'lock texture' button as well, in case you have to run the script again.
Hi !
what does mean "end grains" ?
I agree with you, Remus...
I believe he is referring to the cross cut, or end of the board
Oh !! Ok I see !!
Generally in furniture manufacturing, we don't see end grains.
For example, when we have to make a shelf, we produce a belt around the shelf. So, no end grains.SO the script can apply textures along the longest dimension on each face !
My TextureHelper script was created after a similar request for an easy way to orient wood grain textures. It's not automatic, but it is quick - click a face to rotate the texture, or shift-click to scale the texture (ctrl-click will reverse rotate, and ctrl-shift-click will inverse scale).
Hello Rick !
Yes, i've seen your script, but I thought it can't completly do what I want. That's why I have asked here if someone could create this plugin...
The problem is I often use textures... A plugin which texturises a selection automaticaly would be sooo useful, and fast !
The main problems in creating an "automatic" script are 1) knowing which direction the texture runs (is it up-down or left-right), and 2) reading the user's mind to assign the correct orientation.
#1 is handled by making an assumption that all textures are up-down orientation
#2 could be handled by orienting along the longest edge, but that also assumes SketchUp applied the texture oriented to the short edge.I can look at this and see if a script could work.
Hello Rick !
I think it's not important... Because as you say, SU can't read user's mind.
So I think the solution is to ask a question "is it the right sense ?" after the textures creations. Because we can't know the direction of a texture definition (I think)... If the answer is no, the script have to rotate all the textures perpendicularly.
I had not thought about this problem... So we can't have control on which direction the texture will take ? Means faces have a direction when they've been created ? And textures are placed depending the face direction ? Sorry for my questions...
Really ???
Thank you Rick !PS : Sorry for my "Frenglish"....
Here's a link to a plugin that does what you want for max. Might give developers ideas on how to do it for SU.
