It is currently Tue Feb 09, 2010 12:01 am
Registration
Login Help
Advertise Here
Invitation to the SketchUcation collection
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
FAQRegisterLogin
Re: Invitation to the SketchUcation collection
Postby Hazza on Tue Dec 02, 2008 12:12 pm
Sheet music cabinet:
Sorry, but criteria 4 is "No overlapping solids".
Have a look at the "side slats" component, it overlaps the side rail, the side slat and the post. Same thing with the shelves and the back.
Media Center:
Meets the model criteria, although I have a woodworking type question about the bottom rails. They seem to be mortise and mortise not mortise and tenon joints. Is that a mistake or do you put in a seperate piece of wood to fill both holes?
Dresser:
It's a complex model with many pieces but what I looked at looked all good.
Youth desk:
Same issues as the music cabinet, in the same locations too, side rail, side slat and legs.
Night Stand:
At first the orbiting was weird, then I figured out you had the camera in parallel projection. There are gaps in the woodworking like between the bottom stetcher and the shelf but it meets the criteria.
Queens size bed:
The foot board and head board overlap both the rails. It does not stop it being in the collection but I thought you would like to know some of the components don't have material on all faces, for example the ends and bottom of the side rails.
See all of my SketchUp models here.
Hazza
Postby Gaieus on Tue Dec 02, 2008 12:27 pm
You've become rather picky, Hazza! :P
"Life is like the waistcoat of a summer suit. Short and pointless..."
Should you have any board issue (lost password, not being able to log in or register) at SCF, email me.
Otherwise read The Daily CatchUp or if you are a spammer, click here. ;)
Administrator
Operating system: Win XP SP3
SketchUp version: 7.1.6860 (Pro)
Postby Dave R on Tue Dec 02, 2008 12:30 pm
Hazza wrote:[b]Media Center:
Hazza, are you familiar with "loose tenon" joinery?
When all else fails, play dead.
Operating system: WinXP Pro
SketchUp version: Pro 7.1x
Postby ktkoh on Tue Dec 02, 2008 10:57 pm
Thanks for lookig at the models. I had forgot that I omitted the slots for the slats in the models where the 1/4 panels sit in the rails and styes. I will remeber to include that in the future and will go back and fix the models.
Yes I have started to use loose tenon joints since I built a fixture that works with an old shop smith and works like a horizontal router so long parts are no longer a problem. (except my shop is narrow and crowded)
The gap in nightstand is intentional and required for seasonal wood movement as the shelf is solid wood.
I only use texture where visible from the front and sides most of the time to show the family what thier designed furniture will look like and to get the approval to build.
Keith
ktkoh
SketchUp version: ver 7
Postby Hazza on Wed Dec 03, 2008 6:09 am
Gaieus wrote:You've become rather picky, Hazza! :P
Yes and it's what is not accepted into the collection that sets the quailty. If I let that model slip in why not the next one. Then the next one that is slightly less quailty than that... etc etc.
Dave R wrote:Hazza, are you familiar with "loose tenon" joinery?
No, that's why I asked. I am a SU modeler that does woodwork models, not a woodworker that does SU models.
I have no doubt in my mind that there is heaps of woodworking stuff I have never seen before. That's why I like detailed woodworking plans. I am able to follow the plans with no prior woodworking knowledge.
Now I am familiar with loose tenons... you learn something everyday.
ktkoh wrote:I will remeber to include that in the future and will go back and fix the models.
When you do let me know and I will add them to the collection.
Hazza
Postby Gaieus on Wed Dec 03, 2008 10:01 am
Hazza wrote:Yes and it's what is not accepted into the collection that sets the quailty. If I let that model slip in why not the next one. Then the next one that is slightly less quailty than that... etc etc.
Yes, I know exactly. I was just pulling your leg. ;)
Administrator
Postby Hazza on Wed Dec 03, 2008 10:09 am
Gaieus wrote:Yes, I know exactly. I was just pulling your leg. ;)
Yeah I know you were but it was just in case others came across the thread and thought I WAS being too picky. I would have thought of a witty reply but my caffine system has too much blood in it.
Hazza
Postby ktkoh on Thu Dec 04, 2008 2:01 pm
I understand about standards and I am fine with you saying that the models need fixing to be included. That seems reasonable to me.
Keith
ktkoh
Postby baz on Thu Dec 11, 2008 2:05 am
Heres my contribution.
http://sketchup.google.com/3dwarehouse/ ... revstart=0
With reference to woodgrain orientation, it always used to be a real pain, but now in su7 you can edit the image in pshop. Simply save the texture as a copy in su. Export it to your image editor, rotate the image 90 degrees and voila!
Baz
I love deadlines. I like the whooshing sound they make as they fly by.
Douglas Adams
baz
Location: Mornington peninsula, melbourne, vic, Australia
Operating system: xp pro
SketchUp version: su7pro
Postby Dave R on Thu Dec 11, 2008 2:13 am
Nice chest you've got there, Baz.
I wouldn't want to have to fit those dividers though. Are you going to build it?
Hazza won't like it because the case isn't drawn as separate components. ;)
Postby peweuk on Thu Dec 11, 2008 2:46 am
baz wrote:Heres my contribution.
Baz
I am drawing some cabinets to be made from sheet material in V7 and found this useful feature, and that is what I did at first BUT....
I then decided I wanted the model to work with the cutlist plugin (planning a whole kitchen) and found that to do it this way requires 2 images with different names, one for each material orientation, which causes Cutlist to show the board layout on 2 different sheets (one for each material) instead of one.
So I revisited the model and changed the axis for the parts which needed it (top, shelf and bottom) and this allowed me to use the same texture for all parts.
The cabinets are all created as Dynamic Components in V7 (for easy parametric re-sizing) and the alterations to the X, Y, Z sizing was easily done in the Components Attributes window once I changed the axis.
So if you are designing with a lot of cabinets (such as a kitchen) and are looking to use a cutlist output (either the plugin or a spreadsheet) the axis change is the way to go.
peweuk
Postby baz on Thu Dec 11, 2008 3:31 am
Dave R wrote:Nice chest you've got there, Baz.
Thanks Dave, I actually made this many years ago as my 'masterpiece' (in the sense of the traditional apprentice/journeyman/master, guild system.) I cut each of those mitres on the dividers with a 'donkeys ear' shooting board, and they are a dry fit.
If you push a drawer closed firmly most of the rest slide open, I was pleased with that:)
Not sure I understand about about your component comment re hazza?
Baz.
ps: sorry about the daggy photo, its the one I used for photomatching, all the good shots of this are on slide. (another job to get round to:(
You do not have the required permissions to view the files attached to this post.
Douglas Adams
baz
Postby Dave R on Thu Dec 11, 2008 3:36 am
Ah, the perfect piston fit drawers. You are indeed a master. Excellent work.
You didn't glue the dividers to each other? That's a neat arrangement.
Are you still doing cabinet work.
re: The component comment, The case sides, top and bottom are all one blob of geometry. Hazza's criteria is that every part you'd make in wood must be a separate component. I think your model is fine as it is.
Postby Hazza on Thu Dec 11, 2008 3:41 am
Baz
Dave is right, each piece of wood does need to be a seperate component OR group to met the criteria. The outside box is one group. If I wanted to seperate it into 4 pieces so that I could take measurements I could not do so without many many hours of SU work.
As for the material orientation, you could change that in SU6 without "editing" the texture in an external application:
  1. Edit the component (or group)
  2. Right click the face you want to change
  3. Select "Texture -> Position"
  4. Right click face again
  5. Select "Rotate -> 90 (or 180 or 270)"
Hazza
Postby Dave R on Thu Dec 11, 2008 4:11 am
Hazza wrote:If I wanted to seperate it into 4 pieces so that I could take measurements I could not do so without many many hours of SU work.
Well twenty one minutes, anyway. ;)
by Ad Machine on 5 minutes ago
Concept 3D - Self Service Custom Modeling Shop
PreviousNext
Advertise Here
