Copyright 2010 (c) TIG
[Parts Based on TIG's 'Volume.rb' tools & some ideas from
Alexander Schreyer's 'GetCentroid.rb']
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
CofGravity.rb###
Center of Gravity and Related Properties ToolsUsage:
'Find C of G' This works out a 3D Shape's Center of Gravity and other properties...
Select one 'Group*' or 'Group* of Groups*' [*or 'Component Instance']
= the 'Shape'.
From the Plugins sub-menu 'C of G...' run 'Find C of G'.
[There will be error messages if it's not a suitable selection]
It asks for the Shape's 'Density' and its Units, available
units are = kg/m3, tonnes/m3, g/cm3, tons/yd3, lbs/ft3.
The defaults are 1000 and kg/m3 [the density of water].
So for example, you'd enter 2323, kg/m3 for Sandstone.
The entered Density and its Units are remembered for that Model and
thereafter they are used for the dialog until they are changed.
It also asks for the Shape's 'ID' - the default is taken from the
selected Shape's 'name' - e.g. 'Beam3' - you can enter anything
you wish as an alternative. If it's an unnamed Group its default is
'Group'. If it's a component and the instance also has a name the
definition and instance names are combined - e.g. 'Beam3:Granite'
It processes the Shape [this might take a while - please be patient...]
It adds an overlaid element, named after the 'ID'; it also has a
description added.
This element displays the Shape's ID, Volume, Density and Weight.
It also indicates the Center of Gravity [CofG] & the 6 Axial
Suspension Points [SP].
To see the CofG use Xray mode as it's often placed 'internally'.
Do not edit the contents of a C of G element if it might be used later
in 'Composite' processes.
If parts have different densities then you should group them
separately and process them in turn - you can work out the
'Composite C of G' later...
'Composite C of G' This works out the 'Composite C of G' of two or more already processed
'C of G' elements.
It is important that they remain in their original relationships and
alignments - moving them will return inaccurate results.
Note that these must have been made with the same units of density -
e.g. all in 'kg/m3': although the densities themselves may vary.
Select two or more premade 'C of G' elements.
From the Plugins sub-menu 'C of G...' run 'Composite C of G'.
[There will be error messages if they're not suitable selections]
It processes the selected C of Gs and then adds an overlaid element:
named 'CompoCofG' - its description includes the names of those
C of Gs that have been made composite.
This displays the Combined Shapes' 'Composite Weight', it also
indicates the Combined Center of Gravity [CofG] & the 6 Combined
Axial Suspension Points [cSP].
You can reuse a 'CompoCofG' in subsequent 'Composite C of G'
processes to find another combined C of G etc...
Note:
The C of G element has a special component placed at its 'C of G' -
called 'CofG'. Do not move, edit or delete it, as it might be used in
subsequent 'Composite C of G' processes.
Donations:
Are welcome [by PayPal], please use 'TIGdonations.htm' in the
../Plugins/TIGtools/ folder.
Version:
1.0 20100303 First Release.
1.1 20100303 Accuracy improved. CompoCofG Description improved.
1.2 20100307 FR lingvo added by Pilou.
1.3 20100308 Missing require deB... added.
1.4 20100308 'calculate' becomes 'do_calculation'.
1.5 20100310 'composite' becomes 'do_composite'
Reworked to suit all Macs as well as PC.
ES lingvo added by Oxer.
You do not have the required permissions to view the files attached to this post.
