πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Make Fur v.2.1.0(20140323)
650 Posts 255 Posters 1.1m Views 254 Watching
    tak2hata
    Hello ,All.
    This Plugin is Fur Maker.
    It is convenient to glowing grass etc.
    How To Use: Select Menu From "PLUGINS"-"Fur_EN"
    I am not good at English.So Please look at the appended image.
    NOTICE::This plugin make too much polygons so model will be large size.(Worst case It can not open.)Please use carefully.
    General disclaimer
    I MAKES NO GUARANTEE OF VALIDITY about this script.
    Please use this script at your own risk.
    DOWNLOAD HERE
    Get the latest version from the PluginStore:
    http://sketchucation.com/resources/pluginstore?pln=fur_en
    or AutoInstall from within SketchUp using the SketchUcation Tools
    Versions:
    Since : 2010-04-21--- v0.0
    ....many revisions...
    Rev : 2010-0624 -- v1.4c(test webdialog for mac)
    fixing webdialog problem on mac os.
    (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
    Russian translation by blajnov(Thanks) πŸ˜„
    Rev : 2010-0625 -- v1.4d(Test2 webdialog for mac)
    I wish this work on mac.Thanks Oxer and Mario.
    Rev : 2010-0625 -- v1.4e
    Remove from context menu.
    "Crowd" Problem on mac do not fix yet.
    Rev : 2010-1028 -- v1.5a
    Add preview button.(preview only points of density.)
    in the case of using Inputbox,
    first ,preview points,Press Enter or select "make fur" from context menu.
    Width of some buttons in webdialog increased.
    "Preview Fur"and"Back to Dialog" added to translation word
    I change filename to "fur_en.rb".
    remove older fur rubys from plugins folder.
    fur_lang_**.txt is parameter name translate.
    the usage like this.
    Density|DENSITY
    Length|LENGTH
    This converts "Density" to "DENSITY".
    language translate file copy to sketchup plugins directory.
    If language file is not exist in plugins dir,then parameter name do not rewrite.
    and select it from menu.
    Rev : 2013-06-02-- v2.0.1
    Rev : 2014-03-23-- v2.1.0 : Bugfix.Slider did not work when units are "inch" or "feet".
    Fit to Extension class.
    Improve UI.
    Add function "edit preset list"
    Add function "select language file"
    Including language files.
    Rev :2013-0602-- v2.0.2
    include language file for persian by majid.Thanks!
    Rev :2013-0602-- v2.0.3
    include language file for czech by pepa.Thanks!
    Rev :2013-0602-- v2.0.4
    UI Slider value optimized when units is not "mm".
    Rev :2013-0608-- v2.0.5
    include language file for Spanish by Oxer.Thanks!
    include new language file for Chinese by hebeijianke.Thanks!
    Rev :2013-0612-- v2.0.6
    include language file for Serbian by srx.Thanks!
    Tutorial Video
    Spanish translation by Oxer.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=210#p247640
    Franch translation by Daredevilhttp://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=195#p247400
    Persian translation by Majidhttp://forums.sketchucation.com/viewtopic.php?f=320%26amp;t=28179
    Viet nam translation by ktslambieng(100608updated)http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=300#p250660
    Portuguese-BR (Brazil) translation by Paulower.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=285#p249923
    Chinese translation by hebeijianke.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=300#p250314
    Russian translation by blajnov.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=315#p253618
    German translation:Thanks Burkhard.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=330#p255389
    Czech translation:Thanks Pepa.http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;start=480#p478540
    Serbian translation:Thanks Srx.http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;start=480#p480168
    Zieios makes New ICON for fur.Thank you very much!
    Fur grown Very Thick!
    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;p=478541#p473352
    How to Use.
    How To Make furs.
    add crowd mode.
    crowd mode(multi instance scattring)
    direction using for something like tree place.
    direction using for leaf.
    ![new parameter "direction" and "force"](/uploads/imported_attachments/6qhg_100518_newfur1.png "new parameter "direction" and "force"")
    testing make fur 1_3a
    before_image
    after_image
    grass_with ComponentInstace
    fur_en1.5a--This is Older Version.
    by TAK2HATA
    • P Offline
      Seems very cool! β˜€
        Hey! Welcome to SCF.
        Very nice plugin.
        Got a couple of comments:
        It does not create the grass in the active context. If I open a group or component and select faces it does not add the grass to that group. By design?
        Why are there so many Groups generated? To cut down generation time? Just find it a bit odd that a patch will have grass in multiple locations:
        As for the grass - would it be an idea to make each grass straw a component, and then use scaled and skewed instances of that strand?
          tak2hata
          Thank you for using this plugin.
          Sorry, I will change to create in the active context
          Yes.
          Creating Too Much Polygon is very slow.
          And to use code "entities.fill_from_mesh" must need blank Group.
          This Plugin executes each selected faces.
          Creating Group each new 800 polygons.
          so it parts.
          by TAK2HATA
            Yea - creating geometry slows down as more entities are in the context you add to - I've noticed that myself.
            But would it be faster to make each grass strand to be a ComponentInstance of a single ComponentDefinition? That way one can easily edit the grass afterwards as well.
              tak2hata
              It is nice idea !
              I will examine it.
              I think that time hangs for a moment to change this plugin.
              thanks.
              by TAK2HATA
                meak
                cool plugin
                thanks, thanks,thanks.
                +1 componentinstance! πŸ’š
                • EarthMoverE Offline
                  EarthMover
                  Nice! Autograss for sketchup!
                  Thomthom, is there is a simple code fix that we could implement to have the blades made as component instances, or does that involve some rewriting?
                  Content Creator at Skapeup
                    Dunno - haven't looked at the code.
                    • X Offline
                      xrok1
                      thats pretty sweet! thank you. 😍
                      β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        EarthMover
                        Nice render results...great job with the UI!
                        I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
                          Suggestions:
                          Make the type box and Option box.
                          I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
                          • X Offline
                            xrok1
                            😎 this is greaaaat!
                              @xrok1 said:
                              8-) this is greaaaat!
                              Nice patch. Is that just one plain colour for the grass?
                              • soloS Offline
                                solo
                                This looks interesting....
                                Thanks mate.
                                http://www.solos-art.com
                                  rickgraham
                                  Umm my dialog box for furmaker is blank. ❓
                                  Rick
                                    @solo said:
                                    :shock:
                                    Thanks mate.
                                    Render comp?? πŸ˜„
                                    • X Offline
                                      xrok1
                                      ground cover>Vegetation_Grass1
                                      • jeff hammondJ Offline
                                        jeff hammond
                                        Rick
                                        [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
                                        same here..
                                        no fur for osx 😐
                                        dotdotdot
                                          Ben Ritter
                                          Quite fun to play around with. Thank you so much.
                                          Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                                          Ben
                                          • 32
                                          • 33
                                          • 1 / 33
                                          1 / 33
