It is currently Wed Sep 08, 2010 7:29 am
Registration
Login Help
Advertise Here
extrude (push/pull) without adding geometry inside object
Welcome! Ask and get answered - or just introduce yourself.
FAQMembersRegisterLogin
Postby aquatis on Sat Feb 06, 2010 9:08 pm
Hi, Is the a way to extrude (push/pull) without adding geometry inside the object?
(but still getting the edge around the place where i strated like when pressing Ctrl)
(reason is im exporting the modell)
aquatis
Operating system: Vista
SketchUp version: 7
Re: extrude (push/pull) without adding geometry inside object
Postby xrok1 on Sat Feb 06, 2010 9:19 pm
pressing the ctrl key will toggle the plus sign by the push/pull pointer and toggles new face versus move face. try it its hard to explain.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Operating system: Window7
SketchUp version: SU7pro
Postby aquatis on Sat Feb 06, 2010 9:42 pm
xrok1 wrote:pressing the ctrl key will toggle the plus sign by the push/pull pointer and toggles new face versus move face. try it its hard to explain.
thats what im doing(i guess), but is there a way to make the edge around stay, while preventing the face inside the object from being created.
aquatis
SketchUp version: 7
Postby xrok1 on Sat Feb 06, 2010 10:10 pm
you have to make sure there's no plus sign beside the push/pull cursor or it will create internal faces.
you could also use this plugin http://forums.sketchucation.com/viewtopic.php?f=323&t=25466 which removes internal geometry for exporting. :)
You do not have the required permissions to view the files attached to this post.
xrok1
Postby aquatis on Sat Feb 06, 2010 10:20 pm
Actually the the image showing the "wrong" way is the way i want it but without the internal face(thats how all other 3d software are extruding an surface. So probably the plugin is what im looking for.
here is an image illustrating how i want it http://piclair.com/data/uwkth.jpg
(left box)
aquatis
SketchUp version: 7
Postby xrok1 on Sat Feb 06, 2010 10:29 pm
well you can't do that with push/pull and not get internal faces. you can however make your cube the full height (from image) then select the top or bottom perimeter edges and ctrl copy them up or down as many times as you wish with no internal faces being created. :)
xrok1
Postby aquatis on Sat Feb 06, 2010 10:42 pm
xrok1 wrote:well you can't do that with push/pull and not get internal faces. you can however make your cube the full height (from image) then select the top or bottom perimeter edges and ctrl copy them up or down as many times as you wish with no internal faces being created. :)
Ok, thanks for the tip. the plugin worked and saved me some hours. Thanks!!!
aquatis
SketchUp version: 7
Postby Chris Fullmer on Sat Feb 06, 2010 10:51 pm
Aquatis, are you wanting this functionality for a box modeling workflow? A plugin could be made fairly easily to re-create the pushpull tool so that it does not add internal faces when pushpulling.
Chris
Your intelligence will never fully compensate for my stupidity.
Cal Poly Pomona - BS Landscape Architecture
UC Berkeley - Masters of Landscape Architecture
All my Plugins I've written
chrisfullmer.com - Art Blog
Global Moderator
Operating system: Windows Vista
SketchUp version: 7.1x
Postby xrok1 on Sat Feb 06, 2010 10:57 pm
Chris Fullmer wrote:Aquatis, are you wanting this functionality for a box modeling workflow? A plugin could be made fairly easily to re-create the pushpull tool so that it does not add internal faces when pushpulling.
Chris
i think that may prove valuable to alot of people chris! specially people coming from other 3D apps where extrude doesn't leave these internal faces. :)
xrok1
Postby aquatis on Sat Feb 06, 2010 11:31 pm
Chris
Yeah. If you are offering the thing i´m thinking you are, That would be great! :ecstatic:
aquatis
SketchUp version: 7
Postby xrok1 on Sun Feb 07, 2010 12:05 am
actually "jointpushpull" and the push/pull tool in "SDS" work properly. too bad you have to pre-select the faces to use them, kinda screws the work flow :cry:
xrok1
Postby Pilou on Mon Feb 08, 2010 12:47 am
You have a plug "Remove inner faces" by Wikii ;)
And after use CleanUp by Thomthom ;)
So no problem ;)
Speedy Galerie
Pilou
Postby TIG on Mon Feb 08, 2010 1:03 am
EEbyVector works on selected Edges only and it makes only the side Faces - it makes no end Faces [at either end] - then you can just over draw on Edge on the last set to make the 'capping' Face... :idea:
Global Moderator
SketchUp version: Latest Pro 7.1 and Pro 8
Postby aquatis on Mon Feb 08, 2010 6:46 pm
Thanks for all the help.
Comparing these two:
viewtopic.php?f=323&t=12668&p=92276&hilit=+Remove+inner+faces+#p91814
which one is the best?
aquatis
SketchUp version: 7
Postby TIG on Mon Feb 08, 2010 8:30 pm
My 'manifold' does a lot more but you might not need it all, so the other will be quicker - try both and see... :?:
Global Moderator
by Ad Machine on 5 minutes ago
Concept 3D - Self Service Custom Modeling Shop
Next
Advertise Here
