πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Distace from Camera to object in drawing.
44 Posts 14 Posters 38.6k Views 14 Watching
    Al Hart
    I would like to be able to move the mouse around on a drawing and view the distance from the camera to the object near the mouse.
    I know I could write a tool to do this, but there is probably one out there already. Can someone point me in the right direction?
    Al Hart
    IRender nXt from Render Plus
      Hi Al,
      Here is one - by Rick - and it's free!
      http://www.smustard.com/script/CameraDistance
        Jim
        Maybe Fullmer (or you) can add this to his Onscreen plugin:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=16837
          Al Hart
          @gaieus said:
          Hi Al,
          Thanks, I'll give it a look. πŸ€“
          Al Hart
            Oh Jim, that is an old plugin. I should look at it again. i can't believe it works at all!
              Jim
              Oh sorry - I know how you feel!
                Al Hart
                @gaieus said:
                Hi Al,
                This one returns to distance from the camera t the eye.
                I would like to have a tool which lets you determine the distance from the camera to arbitrary objects in the drawing. I want to use it to set Focal Lengths for Depth of Field calculations.
                This is not a good example, because the eye may be in the same place as the center of focus, but if the eye were raised up a bit, then it would probably be way behind the desired focal point.
                http://wiki.renderplus.com/images/thumb/f/fa/Dof-100-1.0.jpg/350px-Dof-100-1.0.jpg
                Al Hart
                  Ah - yes. That would be a good tool. And for my use, since I'd use V-Ray I'd want it to display the distance in inches as well as model units.
                  Not sure if there's a tool like that out there though.
                    Assuming that you have something selected then
                    model=Sketchup.active_model
                    eye=model.active_view.camera.eye
                    ss=model.selection[0]
                    distance=eye.distance(ss.bounds.center)
                    returns the distance from the camera's 'eye' to the 'center' of the selection's bounding-box...
                    You can of course improve this - another way to get the distance to the 'face' of a selection would be to get the vector between the 'eye' and the 'center' and then do a 'raytest' to find the first point hit and get that distance...
                    distance=(model.raytest[eye, eye.vector_to(ss.bounds.center)])[0].distance(eye)
                    This then returns the 'distance'...
                    You can improve it further by testing if the second item in the returned raytest array contains the selected object and if not redo the raytest from the first item [point] in its array along the same vector...
                    vector=eye.vector_to(ss.bounds.center)
                    rayt=model.raytest[eye,vector]
                    pt=rayt[0]
                    while not rayt[1].include?(ss)
                      rayt=model.raytest[pt,vector]
                      pt=rayt[0]
                    end#while
                    pt=rayt[0]
                    distance=eye.distance(pt)
                    Hope this helps... πŸ˜•
                      Al Hart
                      I took the utilitiestools.rb script in SketchUp, which displays an X,Y location as you move the mouse and changed it to display the distance from the camera instead.
                      The heart of the change is this routine to display the camera distance:
                      	# get camera distance from the eye to a point at (x,y,0)
                      	def get_distance(target)
                      		model = Sketchup.active_model
                      		eye = model.active_view.camera.eye
                      		distance = eye.distance(target)
                      		# display in drawing units and inches
                      		slength = Sketchup.format_length(distance) + sprintf(" (%g\")", distance)
                      		return slength
                      	end#def
                      Try the attached script: get_camera_distance.rb
                      [Edit: I uploaded a new version of get_camera_distance.rb]
                      Al Hart
                        But that measures the eye to target distance...
                        You want the eye to object distance ?
                        The object might be between the target and the eye positions !
                        See my example on how to use the eye>>>target vector and raytest from the eye along that vector for objects in between... perhaps using a selected object as the source [it needs work as it was only a first draft... but selecting a group/instance between the eye and target will give the distance to it ?]
                        πŸ˜•
                          Al Hart
                          There was a bug in get_camera_distance.rb.
                          I uploaded a new version.
                          (One person had downloaded it already - sorry - please get a new version)
                          Al Hart
                            Al Hart
                            πŸ˜•
                            I call get_distance(target) with the point from OnMouseMove() after calling pick(x,y) - not the target of the camera view.
                            I think it is working properly.
                            Here is a rendering after selecting the end of the cylinder as the target point and setting the Depth of Field to be very blurry (3.0).
                            Al Hart
                              I apologize... 😳
                              I hadn't read your script fully - your target isn't camera.target - you have a good idea - it works fine... 😎
                                Bertier
                                hello
                                could that plugin be used to create motion blur in an animation ?
                                thank you.
                                  mpowell1234567890
                                  Cool, thanks. Love it when I can know how far away something is in a model. πŸ˜„
                                  [attachment=1:2q0r3qa8]<!-- ia1 -->get_focal_length.jpg<!-- ia1 -->[/attachment:2q0r3qa8]
                                  > 		return slength
                                  > 	end#def
                                    pibuz
                                    That is a lovely script, but it seems I'm not able to load it..
                                    How can I do that?
                                    Thanks a lot Al!
                                    **EDIT: ok, I moved the original utilities rb to another folder and renamed your script "utilitiestools.rb", and it works: now I can get camera distance 😎
                                    Is there a less homemade or brute method? πŸ˜† Thanks again?
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                    • Dan RathbunD Offline
                                      Dan Rathbun
                                      Renaming files is dangerous.
                                      Make a subfolder of Plugins dir, named: !_autoload
                                      " %(#8000BF)[Plugins/!_autoload]"
                                      Then get my !autoload script here, and put it in Plugins folder.
                                      After.. you can put little scripts that you wish to autoload in the " %(#8000BF)[Plugins/!_autoload]" folder.
                                      I'm not here much anymore.
                                        angeli7on
                                        Hi, I got confused about this.
                                        I try using get_camera_distance but the result aren't DOF
                                        am I missing something ?
                                        here I attach my screen shot
                                        if too small I also upload here:
                                        http://imageshack.us/f/254/bingungdof2.jpg
                                        please advice, thanks alot.
                                        confusing dof
                                          But the distance given by the tool is 703" - not '10' units in the Camera DOF dialog ?
                                          Try using the real equivalent distance [in the correct units for that dialog] to see what happens.
                                          The distance returned by the tool is the distance from the camera 'eye' up to the picked point - in your screenshot it's given in 'inches'...
                                          • 1 / 3
