[code] Timer class
I wrote a Timer class. I'm setting it free here, hoping that newbie developers will find it useful or educational.
The code here is more test code than Timer code. The Timer class is more doc than code. The test code here moves a selected component 100 times by [1,1,1]. (Set frames_per_second to your own taste.)
If you don't know how to move components, look at the
move()
routine in the Timer_test class.# timer.rb - a Timer class require 'sketchup' class Timer =begin Written and placed in public domain by Martin Rinehart, January, 2010. Thinking back to my Java days, I thought that UI.start/stop_timer() methods should really be replaced by a Timer class. You can do three things with a timer: timer = Timer.new( pause_length, runnable ) timer.start() timer.stop() A Timer is initialized with a pause_length (seconds, including fractions of a second, often 1.0/frames_per_second) and a Runnable object. An object is Runnable if it has a run() method that returns a boolean (true==keep running, false==stop running). After the Timer's start() method is called, the Runnable's run() is called every pause_length seconds until the Timer's stop() method is called or the Runnable's run() method returns false. =end # attr_reader :pause_length, :runnable, :running def initialize( pause_length, runnable ) @pause_length = pause_length @runnable = runnable @running = false end def start() @id = UI.start_timer( @pause_length, true ) { @running = @runnable.run() stop() unless @running } end def stop() UI.stop_timer( @id ) @running = false end end # of class Timer class Timer_test # implements Runnable attr_reader :valid def initialize() model = Sketchup.active_model sels = model.selection() @valid = false if sels.length > 0 @sel = sels[0] @valid = @sel.is_a?( Sketchup::ComponentInstance ) end @moves = 0 end def move( r, g, b ) trans = @sel.transformation().to_a() trans[12] += r; trans[13] += g; trans[14] += b trans2 = Geom::Transformation.new( trans ) @sel.move!( trans2 ) Sketchup.active_model().active_view().invalidate() end def run() move( 1, 1, 1 ) @moves += 1 return @moves < 100 end end # of Timer_test fps = 10 # frames per second tt = Timer_test.new() if tt.valid() t = Timer.new( 1.0/fps, tt ) t.start() else UI.messagebox( 'Please select a component.' ) end # end of timer.rb
To use this code, save it into
/some/dir
, not Plugins. Select a component in any model and make sure you can still see it [100,100,100] away from its current location. In the Ruby Consoleload '/some/dir/timer.rb'
Just a very small suggestion: instead of having
you might want to put:
t = Timer.new( 1/fps.to_f, tt )
That way, people experimenting with the code can easily change the numbers, without having to make sure that it's a decimal.
EDIT: Although, now that I think of it, they would only change the fps, not the 1.
Matz made some brilliant decisions, and some other decisions. The decision not to coerce to float was, maybe, one of the other decisions. How many times are you really helped by
9/2
returning 4?
