πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Show and Hide your toolbar
29 Posts 16 Posters 33.8k Views 16 Watching
  • G Offline
    gavvy
    Here is a plugin which can help you to show or hide the toolbars
    Usage put it to the plugins floder and assign it a hotkey!
    πŸ˜›
    Double hit the hotkey ,or load the command twice in a second it will show or hide the "LargeToolset" πŸ˜›
    Thanks for the help by Master Thomthom.
    showhidetoolbars.rb
    • G Offline
      Ehm... Where and how can I find/launch the plugin?
      There is (now?) an entry under my Plugins menu "Relist toolbars". Is that it?
      I get a popup that "Relisted finished" but nothing happens.
      • G Offline
        gavvy
        β˜€
        There is 2 item
        "Show Hide Toolbars" :to show or hide your toolbars
        "Relist Toolbars" :to relist the toolbars (just relist)
        at the begin ,you just to launch the "Show Hide Toolbars" twice IT WILL BE OK πŸ˜†
          charly2008
          it works. Only one click at "Show and Hide toolbar". To reverse it click again "Show and Hide toolbar". The result looks like this! It would be nice if the tool would make sorting a little better. Is that possible in this script?
          I have found a way. When you first use "Show and Hide toolbar" sort the toolbars manually as desired. The next time you use it, all the toolbars are in this sort available again.
          But I've noticed when I undo "Show and Hide toolbar" my toolbars disappear in the top and upper bar. the have to be refurbished.
          Charly
            Burkhard
            Any chance to get it for Mac? It does not work here.
            [http://www.ia-plus.de(http://www.ia-plus.de)]
            • G Offline
              OK, I got it to work, thanks for the help.
              • G Offline
                gavvy
                @charly2008 said:
                Charly
                En....May be Jim will know how to get the position of the toolbars!
                In the Sketchep Api Webside,i can't find the toolbar's position method.
                But like the hotkey ,the position of toolbars are restored in the Registry of Windows.
                If you want to do this ,maybe you have to restart the sketchup .It's that the best way ? 😲
                By the way ,I have not touch the MAC system 😳 πŸ˜† .SO i don't know if it can run on mac or not.
                  Jim
                  You would need to use Win32API on Windows, and I don't know for the Mac.
                  • G Offline
                    gavvy
                    πŸ˜• OH YEAR ~.I remeber a plugin have the example to sort the toolbar in side .em but i don't remember the name of it . 😳
                    Win32api is a good tool to do this ,but it always get wrong for the string 😠 Why?
                    • G Offline
                      gavvy
                      πŸ˜•
                      here is my toolbars . πŸ˜›
                      and the toolbar plugins (modify on Jim's Customtoolbar)
                      • G Offline
                        My problem with this plugin is that it shows all the toolbars that I do not even use when I set it. There are a couple of plugins that I do not use regularly and only switch off when I need them. This plugin activates all inactive toolbars, too (on top of all I also use Jim's custom toolbar).
                        • G Offline
                          gavvy
                          I will upgade it .the pre version ,I had a txt to control which is not show ,and which will show .
                          Next I will add the webDiaglo to control it β˜€
                          • G Offline
                            Please, don't get me wrong, the plugin seems to be very useful - and I am probably one of those few who keeps plugins under the hood and only activates toolbars when needed (I sometimes do not use a plugin for months but then a certain projects comes and I use it daily).
                            Now if only we could save toolbar locations as well so they do not get cluttered all the time when activating / deactivating certain ones.
                            πŸ˜’
                              Jim
                              There it is!
                              UI.set_toolbar_visible("FullToolSet", true)
                              • X Offline
                                xrok1
                                this plugin is awsome! has anyone figured how to get it to open only active plugs?
                                begreat if you could have it only toggle the ones you want it to or only undocked bars as well. that way you could float the larger ones or the ones you don't use as often. πŸ˜„
                                β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                • N Offline
                                  nikus_knx
                                  How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
                                    AFAIK the Scene Tabs can't be toggled through the API.
                                    If you were on a PC you could assign a shortcut key to that View > Scene Tabs menu item and then call a WinScript command to mimic the key-stroke, but since it's a 'toggle', then knowing whether you will turn the Tabs on or off is problematical...
                                    • N Offline
                                      nikus_knx
                                      I get it :
                                      Sketchup.send_action 10534
                                      Do it two times the first time (there 's a bug in Sketchup about the connected checkbox)
                                      Enjoy
                                        @nikus_knx said:
                                        I get it :
                                        Enjoy
                                        However, that's PC only... πŸ˜•
                                        Because it's a toggle there's no way of knowing it the tabs are on before running it, so if they are already off it'll switch them on ?
                                          driven
                                          on a Mac you can use an osascript call to do the same sort of thing,
                                          along these lines, but you need to double check all the escapes
                                          System "osascript -e 'tell application "System\ Events" -e click menu item "Scene\ Tabs" -e of menu 1 of menu bar item "View" -e of menu bar 1 of application process "SketchUp"e- "end tell"'"
                                          PM me if you want a working version or have a play.
                                          john
                                          • 1 / 2
