[Code] Scarpino's SphereUtil Sample ver 1.1.0
Here's slightly modified sphere drawing code from:
[ Code ] Scarpino's SphereTool SampleThis edition is a combo Library & Mixin module.
ver 1.0.0
initial posting (not tested)
ver 1.1.0 -
draw_group() method: fixed call to draw()
4th arg was passing a group object, instead of an entities object.
# --------------------------------------------------------- # file : 'sphereutil.rb' # by : Dan Rathbun # --------------------------------------------------------- # Example of combo Library/Mixin module, sphere utilities. # based on draw code from SphereTool example... # from "Automatic SketchUp" by Matthew Scarpino, pg 260. # --------------------------------------------------------- # Versions: # # 1.0.0 : 02-09-2012 # # 1.1.0 : 02-10-2012 # ~ draw_group() method: fixed call to draw() # 4th arg now: sgrp.entities, was: sgrp. # # --------------------------------------------------------- require('sketchup.rb') module Scarpino # <-- Author's namespace module SphereUtil # <-- plugin namespace ### CONSTANTS # VERSION = '1.1.0' # make the following methods work as library functions # and as instance methods when this module is mixed-in. module_function # draw() # # Args: # center, # [Geom::Point3d] The sphere's center point. # size = 1, # if [Numeric] then the length of the radius, # # if [Geom::Point3d] a point on the surface. # segs = 24, # [Integer] number of segments used for surface. # ents = Sketchup.active_model.active_entities, # [Entities] # mod = Sketchup.active_model # [Sketchup::Model] # # Returns an array of entities belonging to the new sphere. # def draw(center, size=1, segs=24, ents = Sketchup.active_model.active_entities, mod = Sketchup.active_model ) before = ents.to_a segs = segs.to_i # Draw the circles begin mod.start_operation('Draw Sphere') # if size.is_a?(Numeric) rad = size else rad = center.distance( size ) end circle = ents.add_circle( center.position, [1, 0, 0], rad, segs ) path = ents.add_circle( center.position, [0, 1, 0], rad + 1, segs ) circle_face = ents.add_face( circle ) # Extrude the sphere and erase the extrusion path circle_face.followme( path ) ents.erase_entities( path ) # mod.commit_operation rescue mod.abort_operation return nil else before - ents.to_a end end # draw_group() # # Args: # center, # [Geom::Point3d] The sphere's center point. # size = 1, # if [Numeric] then the length of the radius, # # if [Geom::Point3d] a point on the surface. # segs = 24, # [Integer] number of segments used for surface. # ents = Sketchup.active_model.active_entities, # [Entities] # mod = Sketchup.active_model # # Returns a new group object enclosing the new sphere, # within the given entities context. # def draw_group(center, size=1, segs=24, ents = Sketchup.active_model.active_entities, mod = Sketchup.active_model ) sgrp = ents.add_group ret = draw(center,size,segs,sgrp.entities,mod) if ( ret.nil? || ret==[] ) && sgrp.entities.length==0 sgrp.entities.clear! ents.erase_entities( sgrp ) else return sgrp end end ### RUN ONCE # unless file_loaded?(File.basename(__FILE__)) file_loaded(File.basename(__FILE__)) end end # module SphereUtil end # module Scarpino
@driven said:
With Mat's help, I attempted to have this one work along the user drawn axis, so you could e.g. create a string of pearls.
Could you add or suggest how that could be done?
I would suppose you would write a loop of some kind and call the lib methods x number of times, using the same radius, but incrementing the center point within the loop (2 * rad ?). The result would be a line of spheres.
If you wished to write a
Tool
, where the user draws the path, you can mix in the methods using:module Driven class PearlPathTool require('Scarpino/sphereutil.rb') include(Scarpino::SphereUtil) # now your tool has the mixin's methods end#class end
Fixed a small booboo (see the docheader in file.)
@John.. perhaps a good example tool, to make a path, might be a modified edition of the "Examples/linetool.rb"
