[Code] intersect_with?() Group test method
*Author*::*SomeLib*.intersect_with?( grp1, grp2 [, precision] )
Test whether two groups have a boolean intersection. Returns
true
||false
.( Method is non-destructive, and does not change either reference. )
module Author::SomeLib class << self # PROXY CLASS #{ intersect_with?( grp1, grp2 [, precision] ) #{ # Test whether two groups have a boolean intersection. # # (Method is non-destructive, and does not change either reference.) # # grp1 : a Sketchup::Group or Sketchup::ComponentInstance reference. # grp2 : a Sketchup::Group or Sketchup::ComponentInstance reference. # precision : number of decimal places for precision (default = 3.) # # Returns: true, if "grp1" intersects with "grp2" argument. # false, if they do not intersect. # nil, if either are not manifold, Sketchup is not Pro, # or if the groups are in different contexts. #} def intersect_with?( grp1, grp2, prec=3 ) #{ unless grp1.is_a?(Sketchup::Group) || grp1.is_a?(Sketchup::ComponentInstance) raise(TypeError,"(arg 0) Sketchup::Group or Sketchup::ComponentInstance expected.",caller) end unless grp2.is_a?(Sketchup::Group) || grp2.is_a?(Sketchup::ComponentInstance) raise(TypeError,"(arg 1) Sketchup::Group or Sketchup::ComponentInstance expected.",caller) end return nil unless Sketchup.is_pro? && Sketchup.version.to_i>7 return nil unless (grp1.manifold? && grp2.manifold?) return nil unless (grp1.model == grp2.model) return nil unless (grp1.parent == grp2.parent) #} tgrp = nil retval = false mdl = grp1.model vola = volb = grp1.volume.to_l # begin # mdl.start_operation('Intersect Test') ### # if grp1.is_a?(Sketchup::Group) tgrp = grp1.copy else grp1.is_a?(Sketchup::ComponentInstance) tgrp = grp1.parent.entities.add_instance(grp1.definition,grp1.transformation) end # vola = grp2.trim(tgrp).volume.to_l # ### mdl.commit_operation # rescue Exception => e mdl.abort_operation puts(e.message) puts(e.backtrace) return nil else # Sketchup.undo # if prec==3 return puts( vola == volb ? false : true ) else aft = ((vola*(10**prec)).to_i)/((10**prec).to_f) bef = ((volb*(10**prec)).to_i)/((10**prec).to_f) return puts( aft == bef ? false : true ) end end # end #} end # PROXY CLASS end # module
Tested OK with 2 cuboids that intersected at their corners by 0.001" x 0.001" x 0.001"
May I know after determining if the 2 groups/ components/ faces are intersected. How do I get the area of the intersection?
