πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Window Tools 1.1
19 Posts 16 Posters 22.5k Views 16 Watching
    tomot
    I noticed some 300 downloads of Window Tools Ruby thus far. There has been little feedback as to how useful this tool is. I realize not everyone uses SketchUp for Architectural Design.
    But after developing Door Tools I thought I would revisit Window Tools. To bring it in line with what I had learned creating Door Tools.
    As a Designer/Builder/SketchUp users, I find it impossible to use SketchUp without a good layer Plan. Designing for Clients invariably requires changes. And its in this area that SketchUp is weak.
    Making changes to an existing proposal at times can take more time than simply starting over. Hence I made the following changes to Window Tools:
    1. Added a Layer option, all windows are drawn on a Window layer.
    2. Added Wall thickness option, hence Windows will now cut automatically into any wall of a given thickness. This eliminates the need to establish an opening in a wall prior to installing Windows, as was the case with the previous version.
    3. Added the global variable scheme similar to Door Tools.
    4. Revised the Mullion tool, eliminated the superfluous surrounding frame.
    If you think these added changes are worthwhile. Then follow the upgrade instruction in the WindowTools1.1.txt file included in the attached rar file. There is also there is a short video demo attached.
    WindowTools1.1.wmv
    WindowTools1.1.rar
    [my plugins](http://thingsvirtual.blogspot.ca/)
    tomot
      dtrarch
      Hi Tomot
      Very useful and your organization setup is right on.
      Thanks a bunch
      dtr Architect
        Jim
        Nice update, tomot. I just had a thought - for the mullions, would it be easier for the user to just click on the glass to add the mullions, instead of needing to define the rectangle? The window already defines the rectangle. So, select the mullion tool, and then click on the glass - done. Just an idea; not sure if it would work.
          mattg
          Tomot,
          Thanks so much for the really useful tools, the update and the comprehensive intallation instructions.
          I was just wondering how the update works if one is using your window tools as part of Cadfather's SCF toolbars.
          Any difference, or do we just do the same as in the txt. file?
          Cheers, and once again your efforts are greatly appreciated!
          • G Offline
            gogo2suf
            Thank you vary much Tomot.
            It is so useful.
            thank you so much.
            Gogo
              agrazdi
              Great job
              agrazdi
                CadFather
                hi all
                i'm working on the updates of the toolbars, so hold on a little bit more...
                i've been told "i cannot spend 4 days and nights non stop on that computer" 😳
                Thank You Tomot - an even more powerful tool!
                  tomot
                  I welcome all ideas, and anyone is welcome to make changes to Window Tools 1.1 or Door Tools.
                  Jim:
                  I like your idea, although at the moment I don't know how to implement your proposal either πŸ˜„
                  pm me, maybe we can can come up with a solution.
                  CadFather:
                  I don't mind seeing an expanded Architect Tool bar with Window Tools 1.1 and Door Tools
                  being part of it......Go for it! ...... Just don't get me in trouble with your partner πŸ˜„
                  tomot
                    CadFather
                    @tomot said:
                    CadFather: I don't mind seeing an expanded Architect Tool bar with Window Tools 1.1 and Door Tools being part of it......Go for it! ...... Just don't get me in trouble with your partner πŸ˜„
                    πŸ˜† - Thanks Tomot! you will be the first to receive it if i do..
                    • 1 Offline
                      123zxy
                      Perdon, Pero hablo muy mal ingles:
                      Serian tan amables de comprimir el archivo en extension zip?
                      Gracias Carlos
                      • EdsonE Offline
                        Edson
                        Gracias Carlos
                        ahi lo tienes, carlos. there you have it, carlos.
                        WindowTools1.1.zip
                        http://www.mahfuz.arq.br
                        • G Offline
                          gksl4
                          Very nice job,
                          Thanks,
                          George
                            decorarq
                            Muchas Gracias http://www.sketchucation.com/forums/scf/posting.php?mode=reply&f=180&t=14394# very easy to ese thanks a lot
                            • PixeroP Offline
                              Pixero
                              Does the new version also work as the old one? I mean adding windows to existion holes?
                              I usually use that method and if not, could you add both functionalities.
                                tomot
                                There are only 2 lines of code I added in order to cut the opening,
                                which the previous version did not have. I was not able to make this
                                new script automatically recognize an opening from a face, at this time.
                                Hence if you prefer to use the opening method only, then remove the following 2 lines of code. from glass_tool.rb and frame_tool.rb
                                #-------Cut Face
                                    base=entities.add_face(@pt0jj, @pt1jj, @pt2jj, @pt3jj)
                                    base.pushpull -$kqBC45
                                tomot
                                • arquitectomaracuchoA Offline
                                  arquitectomaracucho
                                  πŸ‘ πŸ‘ I am an architect and I feel very good improvement, is revolutionary, I can add options for example 2 windows or sliding panels swing, besides giving the same property of cutting tools wall to door. For the rest thank you very much!
                                  • deaneauD Offline
                                    deaneau
                                    i have now two version of mullion, could you write the mullion.rb so that i have two version to choose in dropdown.
                                    the new version looks like a windows in a yail πŸ˜‰
                                    the first picture is the new mullion
                                    thank you
                                    dean
                                    MADE, BORN AND LIVING IN BERLIN
                                    Big Thank You to all Programmers
                                    Some German words are so long that they have a perspective. M.Twain
                                      ReyT
                                      Your trim tool both side option is not working.
                                      • G Offline
                                        gap007
                                        I have installed New version Sketchup 2014 but your wiindow tools are not working!
                                        Please let me know how to fix?
