🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Self Paced Tutorial Assitant
8 Posts 8 Posters 8.1k Views
    Jim
    Here is a little script to help tutorial makers lives easier.
    It copies the selected geometry along the x-axis, moves the camera the same distance, and finally adds a new scene to save the view.
    It will create a first scene if none exists on first use.
    It creates a menu item called "SPT Copy" in the Plugins menu. Use a shortcut to activate it quickly.
    sptm.rb
    • G Offline
      Jim, this is very kind of you - thanks (I make tuts "once in a while")-
      Also, by default I don't have "scenes" turned on so this would save a couple of steps for sure!
        TaffGoch
        Thanks for the script, Jim. I can envisage the potential convenience.
        I'll give it a test run...
        Regards,
        Taff
        "Information is not knowledge." -- Albert Einstein
          Thank you Jim. This should be really handy.
            RickW
            Sounds like AddPages but with an added geometry copier. 😄
            RickW
            [www.smustard.com](http://www.smustard.com)
              dylan
              Thanks Jim, very useful indeed.
              http://dmdarchitecture.co.uk/
              • E Offline
                ECOTTechTchr
                Does this plug-in work in SketchUp 8? When I tried to install it from Window > Preferences > Extensions > "Install Extension", it won't recognize the file because it's .rb rather than .rbz.
                Thanks!
                  cotty
                  Thanks!
                  plugins with .rb are no extensions and you only need to copy it in the right directory.
                  More details from Thomthom...
                  my SketchUp gallery
