🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] VolumeCalculator v1.8
5 Posts 4 Posters 6.9k Views 4 Watching
    Here's v1.8. For some reason it's just started to Bugsplat on my new PC (Vista). It didn't before ! This new version avoids a splat since it has a two step undo. The splat seems to come from after it's intersected the volume slicing disc group to make entities inside another vol group and then it is trying to erase that disc group within the same commit/undo as the rest. By making 2 undo steps it doesn't splat - go figure ? PayPalButton
    VolumeCalculator.rb
      Tobobo
      Toby
      Philippians 4:13
        AdamB
        This all seems quite a complex way of getting the volume.. The following analytic approach works nicely.
        def calculateVolume(container)
        	volume = 0
        	for face in container
        		next unless face.kind_of? Sketchup;;Face
        		volume += (2 * face.area * (face.vertices[0].position.dot face.normal)) / 6
        	volume
          AdamB
          Doh. And you need to have Geom::Point3d#dot defined - (which is beyond me why it isn't as standard)
          class Geom;;Point3d
          	def dot(v)
          		self.x * v.x + self.y * v.y + self.z * v.z
            Dan Rathbun
            I have posted my rendition of the "no temporary group" calculate volume solution.
            See: Calculate volume on manifold surface without group & explode
            Bonus method for a volume display string in model units:
            See: [code] format volume in model units
            I'm not here much anymore.
