🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Edit Image Material v2.1 UPDATE! (ArchTools)
4 Posts 4 Posters 11.3k Views 4 Watching
    AlexMozg
    This plugin is given by possibility to edit material of image.
    It is possible to change coloured, opacity and aspect ratio.
    And also it is possible to replace texture.
    Usage:
    1. Select Image.
    2. Select "AT - Edit Image Material" from Context Menu.
    3. Edit Material in standart window "Materials".
    Notes:
    ❗ For Sketchup of version 6 and higher (Free and Pro).
    Version 2.1 changes:
    FIX: Colors bars or color wheel are not represented at the first editing of material.
    MODIFY: The structure of plugin is fully done over.
    Plugin is possible it will to be included in ArchTools (my complex of plugins).
      dtrarch
      Alex
      Very good idea and thank you.
      I will give it a shot and see.
      Cannot tell you haw many times I have wanted this feature in SU.
      dtr
        Jim
        I thought version 7 had this already? Maybe it's a Pro feture?
        • G Offline
          There's no difference in the pro and free version in this.
