🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] FredoTools:RemoveLonelyVertices 1.2a - 20 Jul 11
18 Posts 16 Posters 41.5k Views 16 Watching
  • F Offline
    fredo6
    http://forums.sketchucation.com/download/file.php?id=49290
    RemoveLonelyVertices is a small standalone script which will remove (or mark with construction points) the vertices that joins consecutive and collinear edges.
    RemoveLonelyVertices works on a selection or on the whole model recursively.
    It normally preserves all faces and textures.
    http://forums.sketchucation.com/download/file.php?id=49285
    RemoveLonelyVertices is now installed as part of FredoTools.
    See the main post for this plugin for Installation
    http://forums.sketchucation.com/download/file.php?id=49286
    No user manual (see section Quick Startbelow)
    • Language: English and French
    • Menus: by default, it is installed in Tools > FredoTools > Remove Lonely Vertices and also appears in the Contextual menu when there is at least one edge or face in the current selection
    • Icon toolbar: Fredo6 Tool. Icon is not shown by default
    • The plugin is free, for private and commercial usage.
    http://forums.sketchucation.com/download/file.php?id=49284
    [flash=640,480:3bq24fj2]http://youtube.com/v/WbxKv4WJfbc&hl[/flash:3bq24fj2]
    http://forums.sketchucation.com/download/file.php?id=49288
    • Select edges that contain lonely vertices. You can also select faces, groups and components to act on them as a whole. If you select nothing, the plugin will apply the clean up of the lonely vertices to the whole model.
    • Call the Plugin on the selection (main menu or contextual menu “Remove Lonely Vertices”)
    • all lonely vertices are marked with a small green cube
    • a dialog box will appear, asking for action (remove or mark) and whether you wish to process recursively
    • Lonely vertices are removed
    http://forums.sketchucation.com/download/file.php?id=49289
    RemoveLonelyVertices 1.2a - 20 Jul 11: Part of FredoTools. No functional change
    RemoveLonelyVertices 1.1a - 29 May 11: Initial public release
      Thanks Fredo. Great Tool
        JClements
        +1. Thanks, Fredo.
        This should have been built into SU in the first place ... as either an element of the Edit Menu or an option of Model > Purge.
          mitcorb
          Thank you Fredo. This tool should come in handy as an analytical tool prior to using ArtisanSDS. Occasionally, Artisan will ding you about "lonely vertices" in the process of subdividing, although that's not what the error message says. And, point well made by JClements.
            rv1974
            thank you, it'll help in sanitary state preserving.
            • P Offline
              Tricky 😉
                JGA
                Thanks very much, this will be a very handy tool.
                Regards,
                JGA
                • P Offline
                  Panga
                  Thanks for this plugin Fredo, it'll complete the Thomthom's Cleanup plugin. 👍
                  • P Offline
                    putnik
                    I've been wanting a tool like this forever. Thanks very much Fredo6!
                    http://keshas.info
                    • P Offline
                      Pherim
                      Great plugin! Thanks!
                        abilio
                        Fredo u r hell awesome, thank u so much.
                          dylan
                          Thanks Fredo, impressive work again.
                          http://dmdarchitecture.co.uk/
                            CleanUp has the feature - it's the Repair Split Edges function.
                            • F Offline
                              fredo6
                              @panga: Thomthom is right, this is part of the great suit of Cleanup tools. The only small difference is that RemoveLonelyVertices allows to visualize the lonely vertices before proceeding, and also to repair a selection of colinear edges on a full sequence of colinear edges (instead of replacing the whole sequence by a single edge). This is just very subtle (and not sure this is required in the real life), but I needed this feature for another script.
                              Fredo
                                Ben Ritter
                                Thank you again, for your generosity and great work.
                                • G Offline
                                  gokhan0322
                                  thn xxxxxxxxx
                                    seth65475 Newcomers
                                    Glad to be one of the visitors on this awe inspiring web site. Facboook
                                      seth65475 Newcomers
